Question about Denon AVR-3802 Receiver
Set up i just got a denon avr 3802 - i can not get the on screen set up to work - also my sub produces no sound and it reads no back speakers but they are hooked up - ANY HELP
  • mrnathan Apr 20, 2009
    Same problem... the manual is pretty vague. I've attached the monitor out to the TV, but when navigating to the correct AV channel I just have a blank scree ... when I hit the 'setup' button I get nothing on the TV ... don't really know where to go from here. The guys answer on this page is completely incomprehensible ... any help?
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Posted on Dec 29, 2009
I just fixed the issue with no on screen display. You must have an S Video connection between the TV and the AVR-3802. Get an S Video cable and attach it on a device like a VCR and the S Video connection on your TV. Then press the display button on your remote and it should show up on the screen. Make sure that the device you are attaching the S Video cable is able to display on the screen. In other words if it is a VCR, adjust it like you were about to play a tape. Hope this helps. It worked for me
Posted on Nov 20, 2009
  • 682 Answers
Http://www.retrevo.com/s/Denon-AVR-3802-Receivers-review-manual/id/363ag822/t/1-2/.
please make speaker setup again---and make intialization to microprocessors acording to manual above and also set your screen on.
Posted on Aug 10, 2008
Denon 3802 connected to blu ray player but playi g dvds, how do i get dd 5.1?
You cannot get 5.1 sound from DVDs that are not encoded with 5.1 sound. They may be stereo, which will only send sound to the main front L/R speakers.
Nov 23, 2013 | Denon AVR-3802 Receiver
My denon avr 3802 reads no back speakers and there is no power to them. any ideas
You must TELL it it has back speakers and assign the amplifiers for them. It's in the manual. Page 10-12.
May 29, 2011 | Denon AVR-3802 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon avr 3802
First check the speakers one by one ,if they are good your audio amplifier ICs is near to go in to short circuit.
May 27, 2008 | Denon AVR-3802 Receiver
Wiring speakers to denon avr 3802
Those are not compatible speakers for this unit. The Denon receiver does not have any speaker outputs for that type of speaker.
The Denon speaker outputs are full range outputs. Your speakers are not designed for that, they need an amplifier that has seperate outputs for the highs and lows.
By using these speakers you will probably damage them and they will not sound very good as well. The tweeters will end up fried and it is also likely that if one of the speakers goes bad, it will blow one of the channels in the amplifier.
If you really want to do it anyways, and don't say I didn't warn you, you could connect them using the "A" and "B" speaker outputs. Connect the woofers on one set, lets say "A", and the tweeters on the other, lets say "B". Right channel "A" would be the woofer and right channel "B" would be the tweeter for one speaker.
When listening to the unit you would need to engage both the "A" and "B" speaker to hear anything from both speakers, there are buttons on the display for the speakers marked "A" and "B" and in the display you would see little icons that light up when the speakers are engaged.
I can not stress it to you enough that this is not a good idea to use these speakers with this type of receiver. Do this at your own risk and be prepared to pay about $150 to $200 for the repair bill after the amp blows a channel.
Mar 08, 2008 | Denon AVR-3802 Receiver
Losing treble at higher volume
There are two things. First check the sound settings of the DVD player. It might be putting out a lower quality sound on the CD side of things.
Secondly try to determine if the speaker tweeters are working. Connect the speakers if you can to another sound source. If the speakers are good and the settings fine. Then you have a fault in the amp unit.
May 26, 2017 | AAD C-600i Main / Stereo Speaker
Denon AVR-3802 Receiver Logo
707 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
