Question about Dell 922 All-In-One InkJet Printer
Dell 922 AIO won't copy as standalone
This printer was connected previously to a computer, however I "uninstalled" it and it is now simply plugged in to power. It is supposed to function without a computer as a standalone copier but it currently will not do anything except send the message "not connected to computer" across the control panel?? Thanks to anyone who can understand why this printer thinks it is still dependent on a computer...
I dont think A922 is supposed to do a stand alone copying .. please check the manual for the spex ..
Posted on Mar 02, 2008
Printer DeLL AIO 922 is not accepted by Acer with vista premium
You will have to uninstall all the old drivers first as the pc will use those first then re install new driveres from dell
Sep 06, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 printer will not print
Better would be to delete them and update again. Else, try using the opensource driver installtions available.
Regards,
HP
Aug 28, 2009 | Dell 922 All-In-One InkJet Printer
I'm trying g to connect my Dell AIO 922 printer to
You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
Dell 922 AIO NT 4.0 driver is blocked
Download the printer driver from dell web site and try to reinstall. Before reinstall the printer driver you need to uninstall the previous printer driver from control panel->program feature->dell printer
Dell 922 Photo All-in-One
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Regards
http://ithelpdesksupport.blogspot.com
Aug 11, 2009 | Dell 922 All-In-One InkJet Printer
Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 won't print
Myprinter won"t print it says it is the Dell photo aio printer 922 is not working . how can i get it to work. thank you
Jan 26, 2009 | Dell 922 All-In-One InkJet Printer
Aio 922 power light constantly blinks on and off, will not turn on/off or communicate with computer.
Try to unplug the power cable as well as the USB cable of your printer for few minutes. Then plug it back in, check the lights again.
Oct 09, 2008 | Dell 922 All-In-One InkJet Printer
Aio 922 does not scann
» Uninstall Existing Dell™ Printer Drivers
Before reinstalling any printer drivers, it is necessary to remove any printer drivers that were previously installed. Not doing so can cause problems that prevent the computer from communicating with the printer. To uninstall previous printer drivers:
  1. Turn off the printer.
  2. Disconnect the USB cable from the back of your Dell printer, click the Start button, point to All Programs, point to Dell™ Printers and then point to the listing of your Dell printer and then click the Uninstall Dell Printer icon.
  3. When the Dell Printer Uninstall confirmation window appears, click Yes. This process may take several minutes to complete. Do not attempt to power off the computer at this time.
  4. When the Dell Printer Uninstallation window appears (Figure 1), click to select the Yes, I want to restart my computer right now (recommended) option, then click OK. (The system automatically shuts down and restarts.)
    After the system restarts, the printer uninstallation process is complete.
new_note.jpg Note: Do not reconnect the USB cable to the printer until after you have downloaded and reinstalled the printer's drivers.
Back to Top
» Download the Printer Drivers for the 922 All-In-One Printer From Support. Dell.Com
  1. Click the following file name to download the 922 driver: 922ENA04.EXE. By downloading, you accept the terms of the Dell Software License Agreement.
  2. In the File Download window, click Save.
  3. In the Save in: window, click to select Desktop from the drop-down menu.
  4. Click OK.
  5. Click Close when the download is complete.
Back to Top
» Install the Drivers, Files, or Utilities
  1. Locate the file. It is usually on the Desktop or in the My Documents folder.
  2. Double-click the file icon and click Continue.
  3. In the Select the folder where you want to unzip the files to window, click OK.
  4. If a message appears asking to overwrite the folder, click Yes to All. If a message appears asking to create a folder, click Yes.
  5. In the All files were successfully unzipped window, click OK.
  6. Follow the prompts that appear to install the driver.
  7. If prompted to restart your system, click OK.
Jul 30, 2008 | Dell 922 All-In-One InkJet Printer
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 aio printer
it's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
Nov 13, 2006 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
74 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
