There is no VGA port on the computer. Our model number is aspire L5100 We just received this Acer from QVC and there seems to be a missing outlet.
  • 47 Answers
You can also check the back of your computer again, with integrated video card you will see the vga connector, it has a blue color connection like the serial connector and it is not place on the regular location where vga connector are usually located.
You can check this link for the location of the VGA port.
http://images.tigerdirect.com/itemdetails/C/C460/C460-1014/C460-1014-diagram-b-L.jpg
Posted on Mar 01, 2008
    Guru:
  • 147 Answers
Rich,
After looking at the spec sheet for your model - I've come to the conclusion that you have to get it exchanged for one that matches the specs sheet linked at the bottom of my post.
If you click the link below and scroll down a little bit to "Graphics Controller", you will see that the model should have onboard Radeon (which means a video port in the back of your computer).
Reference: http://www.dooyoo.co.uk/pc-desktops/acer-aspire-l5100/details/
Please let me know if this helps. Good luck!
  • Alexander Kogl Mar 01, 2008
    Psybheng,
    Good catch! I should have mentioned that also.
Gfxui stopped working
Graphics User Interface stopped working.......
Based on what?
Error message, or your own statement?
Does an external VGA monitor work, attached to the laptop?
Actually I should state, "External media device"
I have no idea of what laptop we are talking about here, so don't even know if your laptop HAS a VGA port on it.
Might only be HDMI or Mini-HDMI, or DVI.
So I'll stop here until the laptop manufacturer name, and model name/number is stated........
Model name/number is on the Bottom of the laptop.
Example: Acer Aspire 5535-5315
Acer = Manufacturer
Aspire = Model Series
5535 = Model Series number
5315 = Model Number
Post back in a Comment
Regards,
joecoolvette
May 03, 2013 | Computers & Internet
I cannot get Acer keyboard KG-0570 to connect with the computer. Possibly it is not turning on, but with no lights in the keyboard I cant tell. (using stylus to write this) The keyboard came with the...
is this connected wireless or bluetooth
if its bluetooth you have a permissions issue.
if just wierless dongle the dongle may be faulty try another usb port
if it is a usb conection then the usb legacy in the bios needs to be changed.
re-start the comp pus F2 thats will take you into the bios find usb support enable it job done.
Mar 15, 2011 | Acer Televison & Video
I have an acer aspire 5535-6637 and I was wondering if it is compatible with an S-Cable.. If not how can I watch things on my laptop from my TV. Thanks!
You may or may not be able to, it depends in part on your TV. The earliest interface that was compatible would be VGA but it may not be very good on resolution.
The specs for your notebook show only:
DVI Port, VGA port
The DVI (Digital Video Interface) port is available on later sets so check your user guide for either of those two and if VGA is the necessary choice, check which resolution the computer and TV share. DVI will adhere to the same standard for both.
BTW, when asking for help when interfacing devices, include model numbers for both; it saves us time and will give you a more accurate answer with fewer generalities.
Mar 27, 2010 | Acer Aspire 5535-5050 Notebook
My Acer Aspire L5100 computer has some problems with the graphic, or something similar. I have tried to use serval Web Cameras, but none of them works. I have also tried to hook my computer to a...
Sounds like you may have installed Driver Detective and it has taken over. Try removing any usb devices you no longer use or own first, then be sure you have the latest USB 2.0 drivers installed for your motherboard. Next try using ONLY the rear mounted USB ports for your Camera since some PC's have USB 1.0 ports located on the front panel. Good luck!
Mar 07, 2010 | Acer Aspire L5100 Refurbished Desktop PC -...
Aspire L5100 Motherborad Cards Drivers
Google DriverMax, just fellow the prompts and download setup an account and it will find all the missing drivers
Feb 19, 2009 | Acer (90.18612.36B) Computer Speakers
Buying new Acer Aspire one netbook..can you answer some questions: 1. My TV has a RGB port. Will my VGA port be compatible on the Aspire One? 2. What are my options for installing programs and files from a...
There seem to be several versions of that model number 3680-XXXX. It's kind of hard to answer your questions without knowing the precise configuration of the computer you want to buy.
Take a look at just those on the first page of a Google search:
Aspire 3680-?
1. As a general comment RGB does not equal VGA although the latter contains those color lines, it also includes vertical and horizontal synchronization signals.
RGB can even vary; some versions combined sync signals with one of the color lines (usually Green for some reason) and they are separated internally then.
2. - This could be affected by changes in that sneaky -XXXX   3. It depends on both your external drive and which ports are available on the Aspire - if your drive is USB, then there shouldn't be a problem since USB ports are on any PC made in the last dozen or so years. 4. See response at 2.
You will really have to see the exact specs on the machine you are getting to answer most of your questions.
Jan 28, 2009 | Acer Aspire 3680 Laptop
Acer aspire L5100
Just what is it you need help with? The Acer came with a quick start guide.
You received a manual with the PC, start by reading it. If there is something that you do not understand just post you're question's here & one of us will find you an answer.
Mike
May 07, 2008 | Computers & Internet
I can't get my new wireless mouse and keyboard to work with my new acer L5100 desk top
Hello!
Please refer to the user manual in installing the peripherals of your computer.
I send the manual to your email or you can click it here to download. http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/c882f8f08e0b4dc04825737d00388a5a?OpenDocument
select the "AcerDT AS L series.pdf
may this help,
best regards.
Feb 29, 2008 | Computers & Internet
Acer L5100 install problem
I think it would get power through the Moniter so I don't think you need a power cord for the CPU. Hope this helped =)
Feb 25, 2008 | Computers & Internet
Computers & Internet Logo
490 people viewed this question
David Payne
David Payne
