Question about NetGear MR814 Wireless Router
Wireless connection I have been using my laptop for nearly 6 months now on a wireless.I'm using Netgear MR814v2.I just moved to a new place and can get connected with only one problem,I can't get anything online even though my computer says I have excellent connection.Explorer keeps saying ,page not found.I can get online no problem with my desktop.Any suggestions?Please and thank you.
  • 4 Answers
Check out the IP address is provided Dynamically correctly or not. If it is correct the open
http://10.0.0.1
Go to Status - set ip Dynamically - save.
Now, check the website opening.........
Posted on Mar 01, 2008
Mr814v2 working fine but told my network is not secure. how do i secure it?
by logging into the router and changing the wireless settigs to use wpa-psk encryption .
http://kbserver.netgear.com/pdf/mr814v3_ref_manual.pdf
section 4-11
Jan 21, 2014 | NetGear MR814 Wireless Router
I have netgaer mr814v2 which is working absolutely through cable, but I cant see wireless connection on my laptop although i have given the laptop details in wireless settings thanks
First of all please make sure that your laptop wifi switch is on and all the needed driver are installed properly.
Once your have installed all the driver restart both, your netgear and your laptop.
Hope this will solve your problem.
Regards Kartikey
Apr 14, 2011 | Computers & Internet
I can not access my wireless internet network with my new computer. I have a netgear wireless router model MR814v2. I can get onto the internet when directly connected to my modem. However, when I try to...
Hook directly to the router hard wire. Go to configuration page for router and look at wireless security settings. it will show you Wep or some other encryption technique. It will also give you a place to view or change your wireless key. Once you do that write the key down and then connect wirelessly.
Nov 08, 2009 | NetGear MR814 Wireless Router
Wireless connection problem with the MR814v2
Try accessing the router by using the webpage address: ie linksys is: 192.168.1.1
and disable the security settings and save the setting and then try it on the other computers. If that doesn't work then see if there is a reset button on the back of the router. Push it in for a few seconds and then search for the wireless network which should be the routers name with a strong signal. If it still doesn't work then maybe the wireless portion of the router is going bad.
Hope this helps
Jul 08, 2009 | NetGear MR814 Wireless Router
Problem connecting wirelessly using netgear router MR814v2
Hi, you should consider changing your security to WPA-PSK or WPA2-PSK encryption instead of WEP as WEP can be cracked in a matter of minutes, even 128bit keys can be cracked easily. Plus there's no confusion over the four WEP keys generated.
With WPA you choose the key so it can be a word instead of random key, making it easier to remember. Just make sure its not a simple word that can be guessed, and use random numbers or characters so something like 64ranDomWordz92. Its case sensitive too so chucking in capitals makes it even harder to guess. Don't forget to write it down in case you forget it, make sure you write it correctly.
Now you know which key your using, go to manage wireless networks on your laptop and delete any profile you have for your network. Now when you try to connect, it will ask for your WPA / WPA2 passkey, just type it in and hit enter, you should now be connected.
Let me know if you need help with any of the above.
Jan 21, 2009 | NetGear DG834G Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Unable to connect to internet
just try to connect directly from modem ..... if your able to connect to internet just download the firmfare update from the site given below
http://kbserver.netgear.com/products_automatic/MR814v2.asp
Jun 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
NetGear MR814 Wireless Router Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
