Question about Kenmore 659 Electric Dryer
Dryer will not start at all-maybe something with the start button
  • Anonymous Mar 28, 2008
    i have kenmore electric dryer,problem is when pushing start button,you can hear timer running but drum does not spin
  • 156 Answers
Ck door switch first then your power to machine if all good ck the thermo fuse
Posted on Mar 03, 2008
Many possibilities. If you hearing a noise when it's trying to start, the motor may be the problem, or something lodged in the blower wheel preventing the motor from turning.
Oct 02, 2017 | Washing Machines
When pushing the start button the dryer will come on for about 10 minutes and then stop. Then sometimes it doesnt come on at all
If it starts right back up after stopping there is an electrical problem maybe at the motor start switch. If you have to wait for an hour before it will start again then the problem might be that the motor needs to be cleaned of a lint build up.
Oct 23, 2012 | Roper RES7646KQ Electric Dryer
Dryer won't start-Get a buzzing sound when pressing Start
Sounds like motor cost any where from $100 to $150
maybe a little cheaper if find the right place
Apr 24, 2010 | Dryers
WP leq7030kq1 electtric dryer. Won't start, push
If the thermal fuse is ok then the door switch or door switch actuator maybe.
Feb 05, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Try to start dryer when you push button it just hums checked elec. it is okay
You either have something in the blower wheel (maybe fell down thru the lint screen area) or a bad motor . Here in the outskirts of Dallas , we've found snakes which have crawled in thru the vent hose , caught in the blower causing the same....just a hum but no start .
Jul 17, 2009 | Whirlpool LER5636P Electric Dryer
Maytag performa dryer won't run right
bad motor,,should have change it when you had it open,,thats the overload you hearn inside the motor,,when hot it clicks off and when itcool it will run a while than click off...again...need help changing ..
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't run right
The motor in your unit has to be replaced. The centrifical sw can't seem to keep the motor going. The shaft may spin freely, but once power is present the shaft locks up therefore your over amping the motor and it then trips the breaker. Since you already had the unit apart you will do fine replacing the motor. Good luck
dmparenti
Electric Kenmore Dryer
possible bad timer but first ck thermal fuse ..if top mount filter remove back fuse is small white object on blower housing ..if door mount filter remove bottom panel remove lint screen remove 2 screws each side holing lint screen housing in place fuse is behind it ..if fuse cks good suspect timer ..
Sep 07, 2008 | Kenmore 62602 Electric Dryer
My dryer wont run
sounds like something is jamming it up, maybe a drum roller or something fell inside the lint filter compartment. could also be a failing belt. more info would help
Jun 28, 2008 | Dryers
Dryer will not start properly, buzzer operating
more than likely your timer is faulty too much to replace most timers about same price to replace your dryer if not cheaper
Mar 16, 2007 | Candy CIV60 Electric Dryer
Kenmore 659 Electric Dryer Logo
93 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
