Question about Acer Aspire 5630 Notebook
Replace screen My husband broke the screen on his aspire 5630 laptop. When trying to get the old screen disconnected, he pop off the frame everywhere except the upper two corners.....any tips for disconnecting old and reconnecting new would be much appreciated.
  • 100 Answers
If ur laptop have under warranty then please take from nearest Service center.
Thanks
Posted on Mar 01, 2008
Acer web cam not working last 2 weeks,model of lap top is:aspire 5630
Check your device manager for the imaging device ( webcam )
If not found, try booting into safe mode and give a look again in device manager.
If you have any usb devices connected disconnect them
If all of this do not work, you may have disconnected the webcam or could be bad.
Hope this helps
Apr 08, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
Aspire 5630 orbicam.exe has stopped working
try to reinstall the drivers or roll back the driver
Oct 22, 2012 | Acer Aspire 5600 Series 5630-6951 Laptop
How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
Jan 24, 2010 | Acer Aspire 5630 Notebook
LCD screen is black, no lights at all. Before this, was having unstable screen brightness. Replaced LCD Inverter but problem still the same. So, I would like to try replacing the backlight lamp. The local...
The Backlight Lamp. I concur with your thoughts that it's the Backlight Lamp. Holding a flashlight at an angle, can you fantly make out images on your LCD screen?
Generally the Backlight lamp goes first. I've found it's best when replacing the Backlight Lamp, to go ahead, and replace the Inverter also. And vice-versa.
To get at the Inverter, the outside Bezel in the front of the LCD screen, is removed. The Inverter Board is right there at the bottom. 2 to 3 wires, couple of screws to remove, and replace, and you're good to go.
Not so with the Backlight Lamp.
Laptop/notebook manufacturers use different terms when describing these parts, but generally it is,
A.Top Cover. When the laptop is closed, you are looking at the Top Cover.
B.Bezel. The thin plastic frame that goes around the LCD screen, in the front. Usually two to three screws on top, and bottom, with 1 to 2 screws on each side.
There is a rubber cover over the head of the screws, and is held on by a rubber cement like compound.
After the rubber covers are removed, and the screws, the Bezel is removed by inserting a plastic letter opener along the parting line, and worked up, and off.
(Pop-pop-pop, as the plastic formed clips made into the Bezel frame, release from the Top Cover)
C.LCD screen.
The LCD screen has a thin metal frame around it. The LCD screen is held in by thin metal brackets. One on each side.
The brackets screw to the sides of the LCD screen, then the brackets have screws that hold them to the Top Cover.
The LCD screen is removed after un-connecting the power cable, and Inverter cable. The bracket screws are then removed, then the brackets themselves.
Finally you are at the point to access the Backlight Lamp.
Acer Aspire 5630 Service Manual.
http://tim.id.au/laptops/acer/aspire%205680%205630%203690%20travelmate%204280%204230%202490.pdf
(PDF file download. Suggest letting it download all the way before looking through it, or you may break the download connection.
To save a copy to your computer;
After it has Fully downloaded, go up to the top header, and click on the Floppy Disk icon. Second icon from the left. If you hover your mouse cursor over it, it will briefly reveal,
'Click to save this file to your computer or another location'.
In the - Save a copy... window, write down the file name. Then go to the bottom right, and click on save.
If you do Not have your downloads set to go to your My Documents folder, (Documents for Vista), this file will go to your desktop screen.
When you see the file name, double-click on it to open the file.
Disassembling the laptop starts on Page 65. (Machine Disassembly and Replacement)
Removing the LCD screen is on Page 77. There is no guide on replacing the Backlight Lamp.
It is not an FRU. (Field Replacement Unit)
The tech better be back at the shop, and have mucho experience at this!
Reasoning is, that if one Tiny mistake is made, you'll ruin the LCD screen!
Should you wish to proceed this may help,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Dec 06, 2009 | Acer Aspire 5630 Notebook
Acer laptop screen is moved to the right ,it won't take any command
you have a virus try uninstalling your old virus protection and reinstalling http://www.filehippo.com free AVG 9.00
Nov 04, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer aspire 5630 wont turn on
reinstall os from cd.by shutting down in that manner he was probably in the middle of something and didnt close the program resulting in missing sys32 files which is why it wont start.this type of thing happens often and not only for that reason.
do you get anything at all on screen .
can u enter setup(bios)
try removing memory ,make sure free from dust and replace.
no screen is either missing memory,fault with hd(bad sectors)
fault with bios(hardly ever),damaged or dislodged graphics card or damaged cpu(processor)
Apr 12, 2008 | Acer Aspire 5630 Notebook
Acer 5630 ( 3months old)- screen blanked out
Could you tell us what happens when you try to boot up and the last successful thing you did on it before the problem surfaced ?
Any signs of life ? a power issue perhaps ?
Nov 24, 2007 | Acer Aspire 3003LCi Notebook
Non-display of monitor
Try an external monitor if it goes good then your LCD is broke go here: htp://lcdrepair.net
Oct 07, 2007 | Acer Aspire 5630 Notebook
Display on the monitor screen
Try an external monitor if all goes well you LCD is broke. Try these people for more info: http://lcdrepair.net
Acer Aspire 5630 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
