Question about Panasonic GigaRange KX-TG5432 Cordless Phone
New expansion handset doesn't recognize base-station
I had to order a used expansion handset from ebay for the same model, since one of them (of course, the original came with 2 handsets) was damaged. While this "new" handset (when kept on the cradle) recognizes itself as "phone 1", the problem is when I try to use it, it says 'no link to base'. Is there some set up needed here?
  • Anonymous Mar 27, 2008
    Problem: When I push "talk" I get a "no link to base" message. I have gone thru the Re-registering steps on page 41 of the instructions several times. Each time I press "OK" I get an Error message.
  • bcassie94 Nov 27, 2008
    mine does the same thing says no link to base and when someone calls me it rings on their end but not on mine ringers not turned off all plugged in just wont work
Unplug the base for 1 minute to reset system.
Posted on Feb 16, 2009
I have the same problem with the error thing
Posted on Jul 10, 2008
Can't seem to deregister the used HS I bought on Ebay since I don't have it's base.
1. To de-register the orphaned handsets from their old base:
When the orphaned handset says "Connecting..." or "Out of..."
enter *331734 [menu]
and it will soon beep and display "Not registered"
2. To register the new handset to your base:
press the "Handset Locator" button on the base and hold
it until the "in use" light comes on ( ~ 4 seconds ),
then release the button and set the new handset into
the base phone cradle. After ~ 30 seconds it will beep
and display "Handset #" (next in sequence).
3: Note: the base handles a maximum of 12 handsets.
If your system was fully populated ( ie, a handset is
already # 12 ) you will have to clear all the handsets
from the base and re-register them all in sequence.
( it is the only way to 'rescue' the places occupied
by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button
until the "in use" light lights and then starts to blink
( ~ 10 seconds ), release the button --
then press it again briefly while the "in use" light
is still blinking.
2. The base will beep and all handsets that were registered
will display "Not Registered"
3. Follow the instructions above for each handset
in turn to re-register them:
press "Handset Locator" ~ 4sec ( in-use light on ),
set handset into the base cradle, etc.
The manual is available from: www.manualslib.com
but does not fully describe these procedures.
Good luck !
Nov 27, 2015 | AT&T DECT 6.0 Expansion Accessory Handset...
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Additional handsets will pick up calls from mobile phone but not landline calls
Try registering your older handsets with your new base station per the manuals instructions. Also your new base station might be transmitting on a different frequency or some other coded transmission is not recognized by your old handsets. Did the manufacture say the older handsets would work with the new system? They might not even if they did say so.
Jan 09, 2014 | Avaya 3920 Phone
I have a Motorola L404 cordless phone. i bought an additional handset. I cannot get it to register with the base unit. It just keeps saying "registration failed"
On the Motorola L404 series, to deregister all handsets you unplug both the phone and power to the base station. Press and hold the 'find' button while plugging the power back in. The display will show "CL". Continue to hold the find button till the display shows '00' and all the handsets will show 'unregisterd'. You then proceed by registering all your handsets again in the order you want them listed.
Sep 01, 2010 | Motorola Mobility L4 Cordless Expansion...
CWD4900SE - We have just bought a refurbished extra handset but it has OUT OF AREA on the screen. We have lost our manual - is there something we need to do to get the new handset to be recognised by our...
You shouldn't have to do anything special, just place the new handset into the main base station so it can sync to your frequency.
If that's not working, then the refurbished unit is defective and you should exchange it.
Jan 14, 2010 | Cable_and_wireless CWD4901 Cordless...
Need a user manual! I just got a Uniden DECT 2188 phone system
Here's the link to the manual.
http://www.uniden.com/pdf/DECT2188om.pdf
Oct 15, 2009 | Uniden DECT 6.0 Cordless Telephone...
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
Feb 09, 2008 | Uniden TCX905 Cordless Expansion Handset
Adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
May 21, 2007 | Siemens Gigaset SL30 Cordless Expansion...
Panasonic GigaRange KX-TG5432 Cordless Phone Logo
285 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
