Question about Hitachi 51G500 51" Rear Projection HDTV-Ready Television
Blurry screen I recently acquired a Hitachi 51G500A Big screen. The screen is very blurry. I tried to adjust the convergence in the main menu, and the blue and red lines won't match up. I have tried for hours trying to get it right, but it just won't work. I can get the screen halfway decent, but them I can't read the small letters. Can anyone help me?
  • latosha Mar 31, 2008
    I have a 25 inch sanyo and it does the exact same thing. I tried adjusting the color and nothing happened. Please help me, I only had the tv for 21/2 years now.
  • Anonymous May 24, 2008
    Can't ge a sharp image
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Blurry text when playing XBox 360
check these two listing see if yours is same problem.
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
SD Tech
  • 14553 Answers
SOURCE: Hitachi 53UWX10BA dynamic convergence works but blue is blurry
I know this set very well---you are saying convergence adjusts ok everywhere? If you understand that the blue is usually de-focused a little----there are only two ways to adjust the focus of each tube-----
1.) Behind the front speaker grill there is an inspection plate---with it removed you will see a small black plastic block with 6 controls on it; it is the MASTER SCREEN/ FOCUS BLOCK
2.) THREE of the controls left to right are Screen controls(red, green and blue) and the other 3 are FOCUS--IT IS ALL black and you need to look close to identify which is focus and which is screen---you are looking for the BLUE focus control(one of the 6)
3.) With the convergence grid on screen cover the RED and GREEN lens in the set and try to adjust the focus of the blue(I presume you know how to put the set into the Convergence mode?
4.) The only other way to adjust the Blue focus is from the back of the set---with the Red and Green lens covered up place a blanket over the top of the set that covers the whole screen--from the back of the set you will note that all three of the black focal lens have a wing nut---with the convergence grid up and only blue lines present(Green and Red lens covered with a cloth) look from behind the set at the grid---loosen the wing nut on the blue lens and slowly slide the lens left or right until the blue has the best focus possible----if it will not adjust with the focal lens or the front focus control you have a circuit problem.
I do this here for free and if this information helps you take a minute and give me a vote here. If you have any questions or need advice reply to this posting here and I will assist you.
SD TECH
Posted on Sep 15, 2009
Testimonial: "Thank You! Much better quality now! Your advice was dead on. I did not think it was convergence problem....One more Q, where do I send the beer?"
SOURCE: Hitachi 51G500A Convergence Problem
I have no experience at tv repair but I solved this problem and you can too. I bought 2 stk 392-150 chips made by sanyo on ebay for $30. I bought a low life jewelers loupe which is a sort of cap with different lens pieces out on the end of the bill for $10 on ebay. I bought a soldering iron and the smallest diameter silver solder and a little suction bulb and heat sink grease from radio shack for $20.
Take the back off tv. Locate circuit board with ics. remove screws that hold board . there are several wire bridges, snap these apart also. number connections with marker, undo connections. you will note that this board is connected to 3 crts by cable, do not disconnect this cable! This board must remain connected to crts by this cable! (so much for tv repair.com telling you how easy you can remove the board and solder it in your workshop) this board must remain connected to the crts, you can flip the board upside
down but all work must be done at back of tv
undo screws on ics. pry ics loose from heatsink. put on jewlwers loupe then turn board over and heat up each ic pin then **** molten solder into suction bulb. each ic has 19 pins. remove old ruined ics ( shame on Hitachi) my tv was only 3 years old! Put gob of heatsink grease on new ic, spread with razor blade, not to thick or thin, stick new ic thru holes in board and screw to heatsink . solder all pins to circuit board. look at the resistors that are close to the ics. if one is burned black it will have to be replaced, they act as circuit breakers and will burn out to protect other parts of the tv. usually the resistors are fine it was just the cheapshit hitachi ics that were bad.
Put everything back together and turn on tv for 20 min. after 20 min do the magic focus. your tv should focus up and be good as new. I have fixed several hitachi 51g500a in this way. Good luck!
Posted on Sep 21, 2009
Really blurry
Look in main menu for convergence and see if it will adjust--if off either adjustments or a bad chip---picture will look 3d and red or blue outlines around lettering etc.
Oct 22, 2012 | Toshiba 61H70 61" Rear Projection...
Lines, a little blurry, a little movement
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 10, 2010 | Hitachi 51F59 51" HDTV Projection...
The image looks blurry, distorted almost like doub...
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 20, 2010 | Hitachi 51F59 51" HDTV Projection...
The left side of screen is blurry.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Sony KP-51WS510 51" Rear Projection...
I have an Hitachi 46F510. The picture is blurry. Mostly when words are on the screen (i.e. the menu).
The convergence is dead.U need a convergence kit.These websites have it.Tv Repair World.com and Shopjimmy.com.Buy the kit with ur tv model and fix it.
Sep 10, 2009 | Hitachi 46F510 46" Projection HDTV
Pictureis blurry and bottom of screen is wavey
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Televison & Video
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Hitachi 51G500A picture adjustments
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence and other adjustments of many popular brad PTVs are given in detail.
Jun 04, 2017 | Hitachi Televison & Video
Blurry picture
you can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Apr 07, 2008 | RCA P46924 46" Rear Projection Television
May 27, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
