Question about Sony Handycam DCR-DVD505 DVD Camcorder
Sony DCR DVD 505 does n't start when switch it on. I had this problem one month back. I pressed the reset button and got fixed. Now it is not. Please suggest.
  • 4 Answers
Plz try after connecting the adapter and with out battery!
Hope for the best!
Posted on Jan 13, 2009
  • ekram911 Jan 13, 2009
    Hope for the best!
Sony Handycam DCR-SR45 E:31.00 HARDDISK FORMAT ERROR
try connecting the camcorder to a pc using the cable, sometimes a pc can fix the drive. or you will need to do a factory reset. press in the rest button next to the lcd screen for 3 seconds.
Feb 10, 2018 | Sony DCR Video Cameras
Hi, I have bought a Sony Reader on ebay. It is used and when I tried to switch it on it got locked and is asking me to enter a code. I don't have it. Can you please advise me what I can do? Thanks
Hi olena mahero,
For this situation you will need to hard reset the reader, it means wipe out all the information.
You can follow the steps below:
1. Make sure the reader is fully charge or at least half charged
2. Hit the reset button at the back of the reader
3. While the reader shows "Starting Up" press and hold the "Bookmark" button and the "Volume +" (at the bottom)
4. After this the reader will show a blank screen. Turn the reader back on an it will not ask you for a code any more.
5. If the reader goes back and ask you for a code, repeat steps 2 and 3
eBookBoy
Feb 27, 2011 | Sony PRS-505
Hi having problem setting date ,month ,time on camcorder . The touchscreen is not working when i press against screen
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: Please make sure that the Camcorder is turned ON while pressing the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 22, 2011 | Sony Handycam DCR-HC20 Mini DV Digital...
My sony handycam carl zeiss says movie recording disabled. What do I do to enable it?
Most probably it is an issue with the disc. If the disc is corrupted, it will display the error message to prevent spoiling the lens of the Camcorder. Please use a different disc and it should resolve the issue. If the issue persists with different discs, it may require service..
However, I suggest that you reset the Camcorder by pressing the Reset button behind the LCD panel (Near to the USB port) on the Camcorder) Please make sure that you have turned ON the Camcorder while pressing the reset button.
Jan 18, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
Will not turn on or start up..Sony Handycam DCR-DVD300 DVD
Try resetting the Camcorder to the factory settings by pressing the reset button. If the issue persists, try power resetting the camcorder. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 second(or turn the Power switch to ON position for 30 seconds) and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 27, 2010 | Sony Handycam DCR-DVD300 DVD Camcorder
Problem with touch screen
Try pressing the Reset button on the Camcorder. If the issue persists, try power resetting. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
My LCD touchscreen on my DCR-SR45 fades to white
To resolve the issue,
Please open the LCD screen to locate the RESET button.
To reset the Camcorder, just press the RESET button using a sharp-pointed object.
Please make sure that the Camcorder is turned on while pressing the RESET button.
If the issue still persists, Power Reset the camcorder.
To reset the Camcorder, please remove the batterypack from the Camcorder and then set the Power Switch to ON for 15 seconds.
Then, reinsert the batterypack after 1 minute and check if that helps.
Mar 20, 2010 | Video Cameras
Sony reader PRS 505
First, recharge the Reader fully. Then, try a soft reset. To soft reset, just press the RESET button using a sharp-poiunted object. The issue should be resolved. If unfortunately the issue still persist, the reader may require service. Please click here to get it repaired.
Jun 21, 2009 | Sony E-reader Portable E-book MP3 Player
I have a sony DCR-DVD100 that has been in storage for a year and now it will not record. Will play back previous disk however on its screen. What could be wrong?
Try Resetting the Camcorder. To Reset the Camcorder, first open the LCD of the Camcorder to locate the Camcorder(on the side of the Camcorder, next to RECORD and VOLUME buttons). Then, press and release the RESET button using a sharp pointed object. Then, check whether the issue is resolved.
If the issue still persists service of the Camera is required.
You may also try changing the battery.
Jun 14, 2009 | Sony Handycam DCR-DVD100 DVD Camcorder
How to use sony DCR-DVD105 i am new to this
just feed the DVD RW or DVD-R that came with the camera in and select Video from the jog dial and then use the Red button to switch on the rec and again press the same button to switch off the rec u can open the lcd during rec but it will reduce ur battery power , as u use it u will learn it is very simple , u have specific question about menu let me know
Feb 21, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony Handycam DCR-DVD505 DVD Camcorder Logo
101 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
