Question about Maxtor Hard Drive
FORMAT SATA DRIVE 160 GIG
HOW DO I FORMAT A SATA GIG 160 WHAT SETTINGS DO i USE
    Genius:
  • 1,027 Answers
Easiest way is with POWERMAX.EXE from maxtor/seagate website. You can download the bootable ISO from the web and let the software detect the drives and format from powermax.
What I had to do was go into bios and set sata up because the ide channel was primary.But that was just a problem with that board. I was at my church camp and didn't have internet or my software so I set up sata, boot from cd, put in win98 cd, boot with cd support,
at the prompt, typed fdisk, to detect HD, after setting up the harddrive closed out fdisk and at prompt typed cd d:\win98 to change directory to cd win98 dir. then typed format c:\
Posted on Mar 02, 2008
Will a seagate pipeline 500 gb hdd from a lorax dvr work in a pc?
Yes it will work in a PC. All 3.5" sata drives are standardized. Connect it via a SATA cable and you will need to format the drive to work with windows. To do this:
1) Right-click on my computer
2) Click on "Manage"
3) Click yes to allow if any dialogue's pop up.
4) When the menu pops up look at the left side menu and click on "Disk Management"
5) Look for your drive in the list when it populates. It should show a 500GB drive and it may show an error on it since it is not formatted for windows.
6) Be sure this is the correct drive you want to use! Formatting it will erase EVERYTHING on the drive.
7) Right click on the drive in the bottom list and select the Format option.
8) Give it whatever name you want, make sure the format is set to NTFS, check the box for quick format.
9) Let it format, this should only take a few minutes. After that it will show up as a blank drive in My Computer!
Oct 25, 2012 | Seagate Technology 500GB Pipeline HD SATA...
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
Its a 250 gig hard drive and its saying that the memory on the hard drive is a 14.9 gig hard drive. it won't allow for it to put windows 7 back on it. It says there are no drivers on the hard drive on...
This hard drive needs to be repartitioned and formatted first then you should see actual amount. You can do this when selecting the drive in windows 7 installation
Make sure the drive is listed in the BIOS matching your serial, model number, etc incase you purchased this from ebay or second hand.
Mar 11, 2011 | Samsung HM250HI 250 GB SATA Hard Drive
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
IS THERE ANY replacements for YH278 HITACHI 120 GB SATA HARD DRIVE HTS541612J9SA00, THAT IS CAN I REPLACE WITH 250GB.
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
I have a motherboard that has only has one ide conncetions
what you should do is make the 300 gig as second drive and your primary drive is the 80 gig so that you can view and back-up the contents inside it. If you going to install a new copy of Operating system that would be in the 80 gig so that you don't need to format your 300 gig and make it as second drive. Hope this could help you..Thanks..
Oct 24, 2009 | Computers & Internet
CAN I UPGRADE THE HARD DRIVE IN MY ASUS A8M LAPTOP, EXAMPLE CHANGE THE 80GIG DRIVE TO A 160 GIG
Yes you can upgrade the hard drive from 80 to 160 GIG SATA for you to have more storage for your computer files....
Jul 16, 2009 | ASUS A8M Notebook
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
New Maxtor SATA drive into computer with OS on IDE drive?
try to change your master as the 300gig then secondary master 40gig then your slave 20gig. then check it to the bios
Dec 20, 2007 | IBM (02R4087) Motherboard
Maxtor Hard Drive Logo
184 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
