Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Cannot get wireless flash mode to work on my 7D
I have two 5400HS flashes for my 7D. I can get neither to work in wireless mode. I have them synced. I have tried using a single flash remotely with the on-camera flash. I tried attaching one flash as a controller. In short I've tried everything. I can press the AE button to test and everything lights up OK but the flash simply won't fire when I take the shot. I have to believe that this is operator error but I cannot figure out what to do.
Thank you in advance, Steve
  • GarrickBrown Mar 05, 2008
    Thanks Matt,
    I had pretty much come to this conclusion but it's good to have confirmation. I have ordered a cable though so at least I can rig a remote setup if I find it absolutely necessary. I didn't spend much on the flashes so this is more a nuisance than a real problem. If I start doing a lot of portraiture, I will invest in a 5600.
    Thanks for the help.
    Steve
    Novelist:
  • 155 Answers
It is not operator error. I had a similar experience and spent days pulling my hair out trying to figure out the problem.
Unfortunately, the 5400HS is NOT compatible with the 7D. Only to 3600HS(D) and 5600HS(D) are.
The problem stems from the fact that the digital cameras cannot to TTL (real-time) flash metering and have to rely on pre-flash instead.
Because of this, Minolta updated the control protocol to include a signal to tell the flash to pre-flash. Unfortunately, only the two newer flashes recognise and respond to this new signal.
I spent weeks trying various things to get around this, but with no joy. Sorry to be the bearer of bad news, but your 5400HS just will not work properly with the 7D either wirelessly or when attached to the camera.
Matt.
Posted on Mar 05, 2008
580ex won't communicate with Canon 7D (Because I dropped it)
Not sure about the repair costs but why not invest in a Phottix Odin wireless system? I use them in my work and they perform flawlessly. Small and lightweight plus they are wireless which means that the camera can communicate through windows and walls etc.
Hope this helps
Mar 17, 2013 | Canon SPEEDLITE 580EX TTL Flash
I have a 7D and the flash won't pop up. I've tried putting a fingernail in opening and moving side to side while pushing button but it won't pop up.
you have to take it out of auto mode to have any control over flash, try putting it in P mode then press the flash button which is next to the flash. if this doesn't work, take it back to where you got it from to take a closer look.
Dec 31, 2010 | Canon EOS 7D Digital Camera
Flash will not close on Canon EOS 7D
All you need to do is set the camera to shutter priority other non-automatic mode, hold the flash shut and hold the flash button next to the lens opening. You'll hear a motor and a click and it should latch shut.
Jan 30, 2010 | Canon EOS 7D Digital Camera
I have a Minolta 5600HS flash that I have used for four years with my maxxum 7d without a problem until recently. The flash continues to function fine while on the camera and can be set to wireless mode on...
It could be a simple connection that is loose and just need to be put back into position, or it could be a controller circuit that is bad and needs to be replaced. This is not a user repairable problem. It should be sent in for repair.
Jan 20, 2010 | Konica Minolta 5600HS for Maxxum Minolta...
Can my nikon sb 800 flash work with a cannon 7d
yes it work with cannon but in auto & manual mode only not in TTL
Nov 01, 2009 | Nikon Speedlight SB-800 TTL Flash
Indoor picture are dark when using flash---seem like the flash and the camera are not in sync minolta 7d digital camera
If you are in Manual Mode and you set your shutter speed too higher (ie above 250th sec) the shutter blind passes over the sensor when the flash goes off causing a dark section in the photo. Lower the shutter speed to get a better sync. Some camera's default sync speed is 1/60th of a second and sometimes user adjustable.
Remember the longer the shutter speed, the more light will register in the photo. Also boosting the ISO will help extend the flashes range and also record more ambient light for a more pleasing and balanced photo.
Sep 04, 2009 | Cameras
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Cannot get to work right either TTL or as wireless remote
    This one got me too. I assumed it wouldn't need the built-in flash if it was a wireless remote. I still want to know why this is is so. If it needs a pre-flash to set exposure, surely it can pre-flash with the remote SB600?
    Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
    Canon SPEEDLITE 580EX TTL Flash Problem: Flash will not stay in ETTL mode
    u can use the H sync button only with the camera set in semiautomatic or manual modes, it dosent work in AUTOmatic modes
    Oct 23, 2007 | Canon SPEEDLITE 580EX TTL Flash
    Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
    130 people viewed this question
    Top Konica Minolta Cameras Experts
    Computer Links
    Steven Wander
    Steven Wander
    Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
