Question about Refrigerators
Kenmore Replacement Filter
Which replacement filter does the Kenmore SXS Side-by-Side fridge use? I need either the product # or the www.WhereICanBuyIt.com.  (Model #10656572400)
  • Anonymous Mar 25, 2014
    how to replace water filter
    President:
  • Refrigerators Master
  • 2,651 Answers
That would be the PUR water filter number 9030. available through you local sears retailer or possible ordering info on the side of filter itself
Posted on Mar 01, 2008
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Monogram sxs leak
you need to access the back of the fridge and disconnect the waterlines going to the filter base(on the water valve or the main line coming in for example). After you disconnect the waterlines going to the filter base you can pull the base out, and replace the base. Hook the waterlines back up to the same spots you disconnected them from, and you should be good to go.
Aug 03, 2013 | Refrigerators
Need to replace water filter on ge side by side gss25jeta bb model and need to know what type of filter to replace it with.
Pull the old one out and see what it is. Check you owners manual for proper replacement instructions. If you do not have and owners manual copy and paste the below URL into your address bar.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60514-2.pdf
May 31, 2011 | Refrigerators
Hi, have Kenmore fridg model #106. I was told fridge has water filter. Can it be replaced and where is it? Thanks
The water filter is that round looking thing at the bottom of the refrigerator on the front grill. I can see it in the picture you provided. Sometimes, in higher end models, there will be a cover that turns and snaps out. Most units just have a place to grab with your fingers and turn counter-clockwise (to the left as if you were unscrewing it), but don't unscrew it. It only takes a quarter turn to disconnect the filter.
Pull out what you just disconnected and you will have in your hand a plastic (or metal) canister that is the filter. Go buy an exact replacement and usually you have to take the "handle" you used to remove it off the old filter and place it on the new filter.
Oh, probably a good idea to turn your ice maker off and block anyone from using the water dispenser or better yet: pull the refrigerator out and turn the water off.
Good Luck!
Oct 10, 2009 | Kenmore 53092 / 53094 Side by Side...
Frozen, broken kenmore fridge water filter
Hello Leslie176,
They are called reverse twist bolt/screw extractors..
The prettiest I have ever seen came from EASTMAN restoration products..
You are looking for the variable sized set that fits into an ordinary soct wrench with... EXTENSION (should get you into the filter housing...
ELSE
You will hhave to replace the whole Filter housing
IRWIN HANSON Hex Head Multi Spline Screw Extractor Set 25 Piece 53227 Hex...
Check out the eBAY version
(you don't need QUALITY STUFF for plastic
Hanson AHN53204 7 32 034 Hex Head Multi Spline Screw Extractor Bulk NEW...
Apr 13, 2017 | Frigidaire FRS3R5EMB Side by Side...
LOCATION OF WATER FILTER
should be aty the bottom where your kickplate is
Mar 17, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water conditioner replacement
it could be at the lower left hand side front. remove the front grill and look at the lower left hand side. if you see a round thing there, then that is the water filter.
if not then it could be inside the refrigerator room, upper shelve at the back , you can see a round plastic about 5 inches long. cylindrical in shape. that would be your water filter.
tnx 4 using fixya,
drcool
Nov 07, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator filter
Tell me,the filter is it brazed on or is it on with a copper nut?
If you fix a filter remember that silver solder gets real hard if its exposed to cold air the hole time.
Let me know and i can help you with this problem..
Regards....
Sep 09, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore Progressive 335
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
Jan 18, 2008 | Kenmore 335 CADR Air Purifier
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
