Remove Casing from Medion desktop
I've removed all the screws from the back, but the casing isn't budging. How do I get the casing off? I just want to get in to clean the fan.
    Sergeant:
  • 349 Answers
I suspect you need to slide off the top part of the case,their will be some wires attached to it.
good luck
Terry
Posted on Mar 01, 2008
How do i remove the cpu from a medion md42792
Look for a disassembly video on youtube maybe...usually removing CPUs from laptops is an involved job. Usually need to remove battery, optical drive, hard drive, RAM, wireless network card, sound button strip, keyboard and some casing to get to motherboard. Then there will be a heatsink and fan on the CPU, usually involving about 5 screws, usually numbered which you remove in highest to lowest order, and then there will usually be a screw lock on the CPU that you turn to release the CPU. To refit you need to screw back in from lowest number to highest after applying new thermal paste carefully.
Sep 18, 2013 | Medion Computers & Internet
Remove outer casing from desktop PC
Usually just two screws or thumb screws on the back edge. Then lay the tower on the big side. Push down into the case and back and it should slide out. This is most cases. Some will have latches or buttons.
Jan 27, 2013 | Viscom V2 Premier 17'' LCD Computer...
How do you remove the screen on an MD 97860? The hinges are part of the screen.
As with any laptop, you must first remove the casing on the lower half. This will reveal all the internals, including your next step. Youll notice the laptops Hinges are held by the casing. You simply unscrew it, remove it, unclamp it, whatever your laptop does to keep the screen attatched, and unplug the screen.
BUT! You must remove the casing. All laptops are designed to hold one thing by putting together 4 others. Its like a puzzle.
Hope this helps!
Sep 02, 2010 | Medion M3 Composer 5200 PC Desktop
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    How do i remove the harddrive
    What you will do is turn the case around and loosen the two case screws on the right side of the back case. Then slip off the side panel. Inside you will probably find a casing that the hard drive is sitting in, sometimes it's facing you , aometimes it not. If it's not, there is a lever that you can pull to release the casing with the hard drive in it. Then there will be a couple of screws on the side of the casing that need to be taken out to remove the drive completely. Opps, almost forgot, you'll have a cable that comes from the back of the hard drive that goes to the motherboard, You only need to remove the side that's connected to the hard drive, and your done. Reverse these instructions in order to put in a new drive.
    Good Luck
    Mark
    Apr 09, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
    Cannot removed defective CD drive on T135. Cannot find screws to remove front from box
    You don't have to remove the front. Remove the outer casing. + screws in back of tower remove all at outer edege slide casing back. It may take a flat screwdriver to get the case off after that looking at tower from side you willl find small screws that hold drive in place normaly just 2 remove them drive should slide out through the fromt of the cabanet. Don't forget to disconect the power & interface conectiors at the back of the drive
    Hope this helps
    Please leave feedback
    Nov 27, 2009 | Acer Aspire T135 PC Desktop
    How do I remove front facia on my p.c so as to remove my cd/dvd drive
    screws are located on the back,once these are removed casing should slide forward or up,once main casing is removed u will see the screws that hold the cd/dvd drive
    Nov 17, 2009 | Computers & Internet
    Removing outer casing
    If it is a desktop, there should be two thumbscrews in the back. Remove them and slide the side off.
    If it is a laptop, then the RAM is probably underneath a cover plate on the bottom of the computer. Remove the screw and the cover should pop open.
    Jan 13, 2009 | Computers & Internet
    Disassembly manual
    Hi, every desktop pc is almost the same to open up and take apart nowadays, if you want to checkout some of these videos should give you more than enough info..
    http://www.youtube.com/results?search_query=disassemble+pc
    All the best
    John
    Jan 02, 2008 | Sony VAIO PCV-W510G PC Desktop
    Computers & Internet Logo
    111 people viewed this question
    Alun Cox
    David Payne
    David Payne
