Question about Rinnai EnergySaver 556 Air Conditioner
606tr rinnai silent server
My fairly new rinnai heater clicks but wont ignite just keeps clicking any help would be greatly apriciated
    Sergeant:
  • 288 Answers
You are not getting gas for some reason. Check the valve to make sure it is getting power to open the solenoid. It may need to be set to on. If you are getting power to the valve and its not getting gas, check the orifice. Sometimes a spider or other bug will get in there and plug it up. Its a very small hole, so it wont take much to block it.
Posted on Mar 02, 2008
Ignition keeps clicking gas won't light
bad regulator. might need a repairman to come out. or you can replace the regulator yourself.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
May 24, 2015 | Rinnai Heating & Cooling
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
I have a rinnai energy saver 556f our power blew out and it knocked out all our appliances.i am trying to get my rinnai to stay lite but the pilot wont stay on.it goes on for about 3 seconds and then cuts...
Patrick,
Your 556 does not have a pilot light. When you try to start look into the window, you should see an arcing, this is the igniter. With a power outage there is no telling what may have happened. With only limited knowledge of a gas heater you should call a Rinnai service guy.
Good luck,
Tom
Oct 12, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Why wont the ignition click the gas to come on. It clicks for about 10 seconds then turns off.
Make sure the gas is on first and that if you are on bottled gas that the bottles are not empty.
What type of heater is it?
Jun 20, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
My Rinnai 606tr Silent Server continually shuts down and the number 12 appears on the display screen. What's up ?
I know that this is an old post but i had this same problem and i cant find a single answer to this problem anywhere on the net. Rinnai couldnt even give me an answer (let alone even call me back)
Well I figured it out. If you go onto Rinnai's website, you can download the manual, which has the codes and what they mean. Code 12 means Flame Failure. Still this didnt tell me enough. After taking the thing completely apart twice i finally figured out that the heater itself was perfectly fine.
The gas line was the problem. My gas line has a check valve on it right next to the heater. The check valve was not letting a consistent flow of gas to the heater because the heater was drawing too much gas at times, causing the check valve to start to close because it thought there was a leak (so to speak).
All i did was turn the gas valve behind the heater so that it was closed more (not letting as much gas flow through) so that it wouldnt trip the check valve. the heater now works fine and keeps a consistent temperature with no problems.
Jan 05, 2010 | Rinnai EnergySaver 556 Air Conditioner
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Rinnai wall heater won't lite.
You may need to take the pilot assembly apart and clean the pilot orifice. If the pilot does not stay lite you may need a new thermocouple. Good Luck.
Mar 29, 2008 | Heating & Cooling
Our heater wont light
your in the wrong section this is airconditions
Mar 27, 2008 | Heating & Cooling
Rinnai EnergySaver 556 Air Conditioner Logo
252 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
