Question about Goodman GMS90703BXA Heater
Heater not staying lit
My heater has an auto light and it is lighting you can see the flame going into the furnace then it stop a few seconds later it starts up again with the same result. The fan is blowing and its lighting up it just wont stay lit and blow heat . any advice
I found 1 part # GMP075-3 and serial # 9405083641 On a friends Goodman Heating Furnace. The Pilot will light but the furnace will only stay lite for a few seconds. He had accidently grounded out the unit while trying to plug it in. I pushed the reset button and it began working but now will only do the procedure I have mentioned.
  • 2 more comments
  • Anonymous Mar 02, 2008
    The problem with my heater is the igniter will lite but will not stay lit for more than a few seconds. Sometimes it will stay lit and sometimes it will not. Please get back to me with any suggestions you may have. Thank you.
  • hopefaulk Dec 11, 2008
    the pilot will not stay lit on our furnuce for our radiant heater we have baseboards and downstairs we have the floor heater
  • Anonymous Dec 22, 2008
    working with swank heater everything goes through the steps, the unit fires up but wont stay lit for more than a few seconds
  • w_emslie Apr 19, 2009
    furnace starts normally, burners start then inductor motor and burners go out only to repeat start sequence over again.
My furnace pilot light is on but the burners will go off when we put the thermostat on auto. if we keep the fan on the burners will light but turn off the fan and and the burners go off
Posted on Jan 18, 2009
    Sergeant:
  • 288 Answers
You have a low voltage (24) problem. I can be a number of different things. You will need a volt meter. Start at the thermostat. Go to the control board, then the temperature delay, thermal overload, ending at the gas valve. Check for power going in to a part and it should go out. Check for good wire connections. You really need to know what you are doing or else you will be just changing parts. Unless you get lucky this could get expensive. One tip I can give you is to by-pass the delay switch. Just connect the wires together and see if that solves the problem. By the info you gave I don't think that is the problem, but you never know. I would lean towards the board, or the thermostat.
The other guy, check the same and the power into the ignitor box and the high voltage coming out. and the flame sensor. Be careful with the ignitor it packs a punch!
Posted on Mar 02, 2008
Pilot wont light
Pilot won't light ...
If we are talking about an OLD TIME "open flame"
PILOT...
There is a lighting sequence... Push & hold the button
put a MATCH to the gas and count to 30 (thirty seconds)...
Will USUALLY get the job done...
The HOLDING for 30 seconds... ALLOWS
time for the THERMOCOUPLE to warm...
assuring the flame is active and RAW GAS is
not escaping (important safety feature)...
MOST common cure for FAILURE to stay lit: REPLACE
that THERMOCOUPLE...
Still carried by most hardware stores... it is important
not to OVER-TIGHTEN the new replacement...
Ideally... you should MEASURE THE LENGHT and
make sure you are buying the right length/size...
Amazon example
Honeywell CQ100A1013 24 Inch Replacement Thermocouple for Gas Furnaces...
eBay example
Universal Thermocouple 24 works with Most Gas Furnaces water heaters...
I buy two...
(I have a SPARE IGNITER or Thermocouple for
every oven, water-heater... heater and patio heater
that keeps my wife happy).
Carnac the Magnificent
Nov 18, 2017 | Heating & Cooling
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Heater will fire but wont stay lit.
I assume that you are referring to a natural gas forced air furnace. If so you just described the symptoms of a dirty flame sensor. Remove the sensor with a 1/4" nutdriver. clean the flame sensor with a small piece of fine grit sandpaper or emery cloth. replace the sensor and turn the furnace back on.
Good luck.....
Apr 11, 2009 | Heating & Cooling
I have a goodman gmpn 100-4 REVB furnace that will not stay lit
If the igniter lights the burners the ignitor..... is not bad. Its like a light bulb.... it works or ot doesn't.
You are describing a dirty flame sensor. Dishonest contractors will sell you a new ignitor but clean the flame sensor when the are installing the ignitor. It is located at the opposite end of the burners than the ignitor. It has one wire going to it. Remove it and clean the rod with a piece of fine grit sandpaper. this should be done every year before heating season.
Good luck
Mar 28, 2009 | Goodman GMS90703BXA Heater
Rheem criterion II flame stays lit for a few seconds then only cold air blows through the house
Your furnace needs a tune-up. MODERN FURNACES REQUIRE REGULAR MAINTENANCE!
Mar 10, 2009 | Goodman GMS90703BXA Heater
Ignition failure code on
Sounding like a flame proving device is failing to sense flame. Try to clean the device with some steel wool. It is located right next to the last burner looks like a thick wire. Take the steel wool and gently rub the carbon that has built up off. Should only take 4 or 5 strokes. Let me know it that did it. Ken
Nov 30, 2008 | Coleman Propane Forced Air Heater...
You have a common problem. You are losing the 24v somewhere. You will need a meter to repair it, as there are many part that could be the problem. Changing parts without knowing can get expensive. If you have a meter and know how to use it, I can help you.
Feb 17, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90703BXA Heater Logo
398 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
