Question about Kenmore 63942 Dryer
Kenmore gas dryer wont heat, model #11074832400
The dryer spins but there is no heat. what is the issue here? what is the fix for it? and how do i go about fixing it?
  • 2 more comments
  • Anonymous Mar 22, 2008
    how do you know if the thermocouple is bad?
  • Anonymous Jun 16, 2008
    my sdryer spinds but no heat comes out
  • jfabulous Feb 04, 2009
    Had the same problem - won't heat - don't know what to do?
  • Anonymous Mar 23, 2014
    I am getting no heat from my dryer... What can I do to fix the issue?
  • 185 Answers
Check the igniter,thermal fuse,operating themastat there is a small plastic piece on the lower left hand corner pop that out and when you turn your dryer on it should be glowing red if not its the igniter
Posted on Mar 25, 2008
  • 156 Answers
Can be a few things ck your power first make sure 240 volts then the thermo fuse then the element
Posted on Mar 03, 2008
How to check the door switch on my kenmore dryer 11074832400
access switch and tape the leads together,,, if dryer works bad switch. if not something else is problem,,( of course unplug dryer before unplugging switch)
Aug 28, 2014 | Kenmore Dryers
Why won't my kenmore 80 series dryer start
check all your power connections, if power is all there then check the motor it might need to be replaced
Aug 27, 2014 | Kenmore Dryers
Our Kenmore Gas Dryer: (Mod:#11074832400) Flames up but then goes out after short while...Turn it off a while and it will do the same....Is this the "Thermal Cut-Off"?
No the Thermal cut out is a one time deal. Once it is tripped it is tripped. It sounds like you may have a bad coil on the control valve.Hope this helps.
May 31, 2011 | Kenmore Dryers
My kenmore 80 series starts, and spins, but wont heat... why?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 18, 2010 | Kenmore 63942 Dryer
My kenmore 80 series dryer wont heat up how do i fix it
could be the igniter or thermal fuse if you hear the gas valve click open and there is no glow inspect the igniter for a hot spot or white spot where the brek occured,some dryer will spin but not heat up if the thermal fuse is blown
Mar 20, 2010 | Dryers
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore Dryer will not start
my kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Jan 08, 2008 | Kenmore 73952 Gas Dryer
How do i change the ignitor in my dryer
First, why do you think ignitor. In all the dryers I fix only 1 dryer in 999 need the ignitor replaced.... Hit me back before midnight for more help........
Dec 12, 2007 | Kenmore 74832 Gas Dryer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 63942 Dryer Logo
692 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
