Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Read only drive
When I plug my 250 GB Freeagent drive into my MacBook Pro laptop it shows up as an external harddrive but won't let me put files onto it or take files off of it as it's listed as a "Read Only Device". How can I fix this?
Fixed it by partitioning the Drive and formatting the Partition to Mac
Posted on Mar 01, 2008
My Seagate FreeAgent Go250GB become write protected for Macbook, but works fine on windows laptop. How can I fix this issue?
It's probably formatted to the wrong filesystem; Macs prefer HFS+, Windows prefers NTFS, but they both can read and write FAT32. I'd recommend using the Mac's Disk Utility application to reformat the drive to be FAT 32 (but be careful, this will erase the external hard drive, so back up first!)
Apr 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I want to transfer data from my old computer to my new conputer using my Segate 500 GB back up drive. How do I do that?
First, you need to choose all the files you want to back up and put that into a folder then plug in your external harddrive click "my computer and double click your external hard drive and it will open another window. just drag all the folders that you want to backup and paste that to the new open windows which is your hard drive then thats it. just remove the external harddrive correctly and wait for the file to be complete transferred.
hope this helps. please rate my solution thanks.
Jan 12, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to I reallocate my 500 gb external hard drive so I have more space for my laptop - I have 250+GB space avilable for my destop but I am getting "disk full" for the laptop.
you should be able to connect the external hard drive to your laptop and the drive should show up under my computer. Then just drag and drop or cut and paste any files you want to move to the external hard drive.
hope this helps.
May 21, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Free Agent Drive cannot be modified? Worked before...
Ok,
Sounds like it's one of three things then
Disk trouble from unplugging the usb while the unit is still "running" and not yet finalized. Running CHKDSK /? /F in the run box where ? = extrenal drives lettrer. Then restart the computer(done from windows PC with drive attached)
Shell trouble I have already advised a dozen or so people this week that if CHKDSK doesn't work, replace the shell with a new one and see if the hard drive works in the new shell.
Failed harddrive, of course this is always an option. If neither of the above suggestions works then it's possible the hdd has failed and you may need to send it to a pro if you have any files on it that need retreiving.
Hope this helps FixYa, if you need additional help just reply to this by adding a comment.
Chris
May 22, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Dec 24, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Can't erase files on Seagate FreeAgent Go
Under the Gear looking icon located on each window, there will be a delte option. Just click what you would like to delete, click the icon and press delete.
Let me know if this works.
Dec 02, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Power to my Seagate FreeAgent Pro 500GB
I think you screw yourself... you have just burn your files
Sep 24, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partition
decided to use Free Agent Pro dedicated to Time Machine and purchase a separate harddrive to just use as a 2nd external drive to store photos, etc.
May 28, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent external harddrive
In any Mac OS System/Computer It cannot and will not write files to a NTFS Drive, but it will read.  The easiest solution for this is to search google for a program called "macfuse" this should fix the problem :)
Jan 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
268 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
