Machine wont start
When I push the power button then the start button the machine wont start (does not fill with water). It seems to be an intermitent problem as the other day it did start filling so I paused it opened the machine, put my clothes in, but when pushing resume it didn't start again. My theory is that it thinks the lid is open so it wont go into cycle, but I cant find any machanical indicator for the the machine to know when the lid is open or closed. Any ideas?
  • 2 more comments
  • Lemonfresh Mar 01, 2008
    It is Fisher and paykel GW608. So if it isnt the lid actuator that is stopping the water from filling, any ideas of what could be? Web site said there is supposed to be a tech manual in the control panel but I can't find one.
  • Lemonfresh Mar 02, 2008
    Thanks for the advice. There is no error lights indicated; the cycle either goes through the whole cycle without a hitch or it just wont start to begin with (although all the lights indicate it is ready to start). I'll have a look at the blalance switch as you suggest and see if I can find a problem there. I managed to do a successful load yesterday but that was more fluke than anything, 95% of the time it wont start. Thanks again for your advice.
  • steveme Jul 02, 2008
    I have a wwwse3160aoww ge profile washing machine. I used it this morning and after it finished washing, I put a big comforter and tried to start it. It would not power on. I removed the comforted and started it again, it is the same problem. Changed the power outlet, but no response. Any ideas?
  • Ron Coons
    Ron Coons May 11, 2010
    model and manufacture???? your on the right track i believe, it wont work without lid actuator activated, wash or spin any way, should always at least fill with water though
    President:
  • Washing Mach... Master
  • 2,651 Answers
Oohhhh. gwl10 os asearly as my knowledge about these machines go, placing a call to manufacture migh be helpfull . do any indicator lights blink when washer stops??? those are the codes so write down which ones are blink, if i had to guess though id lean toward an ou-of-balance switch failure. on my gwl10 thatslocatedunder console on right side, white bar hanging down measuring time tub hits into it. the switch usally corodes out. hope thats somthin anyway
Posted on Mar 01, 2008
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Why does drain motor start when pushing the start button on the door before the door is closed?
It's almost certainly the float switch in the bottom of the machine. In the bottom is a polystyrene 'float' that is either active due to water in the bottom or is faulty. Tip your machine to the side and remove water and try again, bridge or replace switch is also an option
Jul 07, 2013 | Bosch Dishwashers
Washer will not fill with water when the start button is pushed.
Have you checked the water pump? I would say it is that or the button may be defective.
Feb 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Fisher and paykel smart drive top loader , Wont fill properly .
Well where to start .....
This brand has a hell of a lot of quirks.
The first thing to try is this : With the power on at the wall and the machine off ,push and hold down the start button , then push and hold down the power button you may hear up to 3 beeps at this time (hold down the buttons for 5 seconds then release) turn machine off and turn it back on and just push start button.
What this does is re programes the computer ,then just leave machine to run cycle
Jun 12, 2009 | Fisher and Paykel Washing Machines
Washer won't run , push start button just beeps
in order to determine what is the cause of your problem , please provide the error codes an model number so we can figure out what is wrong with it, has anyone set anything heavy on top of the machine if is a top load machine, first guess if you have power to the machine would be look into the lid swtich an go from there....
May 28, 2009 | Bosch Washing Machines
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Washing Machines Logo
431 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
