Question about LG DLG5932W Gas Dryer
DLG5988W Gas dryer
My cloths have a kind of burnt smell to them after every cycle.It seems to be getting worse with time.
  • KMCH Mar 01, 2008
    5 ft of pipe 2 90 deg ells and side wall vent clean?
  • 3 Answers
You may have lint build up inside your burn chamber. Un-plug. Remove the top and the two screws inside the bottom of the door opening. This will allow you to lean the front back and access the door switch. unplug the switch and remove the wiring from the plastic clips. Set the front aside and remove the lint trap and the two screws securing the duct to the fan/frame. On the right side of your unit as you are facing it look using a flashlight you can see the burn chamber. It should have burnt lint inside if this is your smell. Using a shop vac and the smallest tools you have reach in and vacuum out this chamber and all the areas around it. Be very careful when vacuuming out the chamber not to disturb the flame sensor on the left side. This small piece sits in front of where the flame comes out and you don't want to move it. After clean carefully re-install your parts being careful to get the felt seals in place. If you felt seals are damaged you will get lint in the burn chamber again and the smell will come right back.
Posted on Dec 14, 2009
  • Lou Cripps Dec 16, 2009
    One other thing... If you have done any painting, staining or cleaning with oil based products this will cause a burnt smell in you gas dryer and cloths. This can occur for up to a few weeks after you used the oil based product. This may sound a bit odd but trust me it will cause the burn smell. You may notice this same smell if you have a gas range.
    President:
  • LG Master
  • 2,651 Answers
You might want to check you venting, if tis not clear, your lint might be building up inside machine and burning off as you use your unit.
Posted on Mar 01, 2008
What's your problem? burnt smell in clothes
I would check your exhaust line, because all the symptoms you are listing are caused by a restriction in the air flow.
May 19, 2012 | Maytag MGDX500XW Dryer
Washed clothes with gasoline on them. Put into dryer now washer and dryer smell like gasoline. How do I get it out?
To remove gas (petrol) smell from clothing, soak overnight in baby oil (use like you would downy), then wash in baking soda, then wash with normal detergent. It will rid "gas smell" from an entire basket of clothes. Air Dry ONLY
From ehow website:
Step1
Buy a bottle of baby oil. Since gas is an oil based product it is going to take an oil based product to clean the gas out of your clothing. Baby oil is a great product to use as it shouldn't, in most cases, cause further damage to your clothing.
Step2
Soak your clothes with a bit of laundry detergent, water, and a generous portion of baby oil. Also dab some right on the stain before soaking.
Step3
Swash your clothes in the water for a while and let them sit for about five minutes. Transfer the clothes into your washer, once again remembering not to mix them with any other clothing, and let the cycle finish.
Step4
Wash the clothes. If you have a top load washer, let it partially fill up about 1/4 of the way with water. Put some of the baby oil in the wash with the clothes and swash it around a bit. Once the washer cycle begins, add the detergent and let the cycle finish. Make sure that your gas coated clothes are the only clothes you put in the wash.
Step5
Dry your clothing. Make sure you only AIR DRY on a clothes line these clothes. It could take more than one wash to get all the oil out of your clothing. If you use the dryer after the first, or even the second time, you could risk starting a fire in your dryer.
Step6
Check and see if any smell remains in your clothing. If the smell of gas remains on the clothing repeat the wash with baby oil again until the smell is gone.
Sep 04, 2011 | Frigidaire Electric Dryer
I have an LG gas dryer, lately when the dryer has finished my clothes has a burning smell to them. I recently painted and noticed the smell at that time. Though the paint smell is gone the burnt smell has...
Mark, My name is Hal and having trouble understanding where you painted. Did you paint the inside of the drum? Or did you paint the house interior?
If you painted the inside of the drum did you use a high temperature paint? If not, that could be your problem since the dryer does get very hot inside and it could be melting your paint.
Aug 06, 2011 | LG DLG5988 Gas Dryer
My Kenmore 80 series dryer seems to operate normally, except for a horrible "burnt chemical" smell in the dryed clothes. It almost smells like the gas is not exhausting correctly. Could it be the...
A lot of time a chemical smell is the result of blown capacity where the electrolitic is leaking out. Large caps are used in the moter start circuit and are usually located close to the motor. After awhile there will be an impact on the motor starting and the performance of your machine.
If it is the belt slipping you would get a burnt oil smell. If it was the blower motor or the drive motor it would be more of an electrical smell - burnt plastic type.
Jun 21, 2011 | Dryers
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
Aug 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My clothes smell burnt
If you have done any recent painting or drywall work, oftentimes the dryer will breathe these fumes and it will affect the smell of your clothes. (Just had the same problem) Maybe let the area air out and see if that corrects your problem
Nov 28, 2007 | Kenmore 74832 Gas Dryer
LG DLG5932W Gas Dryer Logo
248 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
