The computer when ask to shut down try to disconnect itself from all programs and then it shut down. If one of the program does respond then the computer hangs waiting for that program to terminiate.
Recently innovated computers least require updates to capture an improved experice. Ascertain that the devices that require connectivity is within manufacturered compartibility. In situation that the new device asks for resource that available is indication that alternate peripherals are not compartible Refer with the devices user guides to ascertain the methods available for impressions. Alternately, refer with a technicians expert to install.
you may check youe BIOS settings by restarting the pc and repeatedly press F2. Then check your PC or system settings wherein there is a list of peripherals such as Floppy Disk, CD/DVD drive, Network Adapter etc. Those peripherals will tell you if they are enabled or not. use your arrow keys to select and check if the CD/DVD drive is enabled. Then press F10 to exit and hope that CD/DVD would work...
i hope you installed the correct bios update that matches your laptop's model , if yes then
try to delete the peripherals from device manager and detect them again
Most modern sound chips use an AC'97 driver
Go to www.realtek.com and download the driver listed in the support area of the web site. This driver should suffice. Windows 7 is a little more of a pain as many peripherals do not have Windows 7 compatible drivers as yet. At this stage, try the realtek website..
