Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Architect Side by Side Ice/Water Dispenser problems
Two issues going on. First, the Ice dispenser will only produced crushed ice, even when switching the button to cubed. The second issue is that the light that goes on when you use the water dispenser is not functioning. Bought 2 replacement bulbs from a parts store for this model, but they aren't working. I suspect a short somewhere but don't know how to get inside the door panel to see.
Do you have any tips on where to begin?
Thx
  • Anonymous Apr 06, 2008
    We have exactly the same problem. Unfortunately, according to the repairman who came to repair our dispensor, the only repair is a new door (approx. $800 plus labor).
    He tried splicing the wires cut by the bottom hinge but said it probably wouldn't hold for long. According to his experience, he's seen several customers with this same issue - ALL Kitchenaid customers! He's never seen it on any other brand because Kitchenaid was the only one to run the wiring over a metal hinge where they constantly rub and wear down.
    Good news is that I saw another blog today in which a customer had contacted Kitchenaid who seemed quite aware of this "manufacturing defect". They provided the door at no cost and the customer provided the labor for installation.
    Good luck - I'm calling customer service tomorrow!
  • matt785 Oct 26, 2008
    ice maker works,water dispenser works,but the entire ice dispenser on the door doesnt work.we had the same problem in the first year of operation and it was fixed under warranty. what now???
    President:
  • KitchenAid Master
  • 2,651 Answers
Most common place fora problem is in wire harness under freezer door hinge, within the weblike wireharnes likly to find a broken or split wire. before lookin for it follow harness back a few inches and unplug the harness connector(just incase you hit a live wire you'll short somethin out. its not the easiest place to do it but you would need to remove the screws attaching it to hinge, perhaps cut a plastic wire tie to reconnect wire, straigh wire connector only way, not enough room for wire nut,,,That is if you find a broken wire of course. Oh by the way wire harness not replaceable need toorder complete freezer door , only ohter repair
Posted on Mar 01, 2008
My ice maker produces ice just fine, however when I try to receive "Cubed Ice" it dispences it "Crushed". It makes no difference if the front panel "Cubed Ice" button is pushed or the "Crushed Ice" button...
Not sure what brand you have but I had a similar problem with a dispenser once. The ice dispenser would freeze up and couldn't change over from one to the other and I'd have to take it out and let it thaw occasionally and then it would be fine for several months again. If your ice bin is in the door this may be what you need to do.
Jan 25, 2018 | KitchenAid KSRG22FK Side by Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side frig (KSCS25IN) will not dispense cubes
Check the drive gear for the agitator, It might have gotten stuck on ice too many times and stripped the gear. Good luck!
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid kscs25fjss01 (2002) front panel not working
Hi
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Apr 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
237 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
