Question about NetGear WGR614 Wireless Router
Router sharing when im typing somthing on the main computer it comes up on my 2nd computer so how do i get that to stop.
  • 1 more comment
  • darbybelge Mar 01, 2008
    when my mouse moves so the does the other mouse in the other room on my 2nd computer and every thing i type comes across on the other computer no matter what i type it goes to my other computer. ineed to know if there is a settings that i can fix to stop this.
  • noreka May 15, 2008
    how to change PPPoE encapsulation in PPPoa for NetGear WGR614 Wireless Router
  • Alexander Kogl May 11, 2010
    Can you better describe your problem please?
  • 91 Answers
Your problem is because the 2 wireless mouse and keyboard sets are interfering one another, you can try to enlarge the distance between the 2 transmitters as far as you can, or check in the set manual if you can change it's frequency, or you can replace one set with a set of different company, or change it to a wired set.
Posted on Mar 04, 2008
  • Ronen
    Ronen Mar 04, 2008
    by the way if you press the connect button on the bottom of the mouse and then the connect button on the transmitter it makes a connection,
    do it on each computer when the other computer is closed, and it should be ok.
    Guru:
  • 147 Answers
It sounds like your computers are virtually connected somehow by Remote Desktop or VNC. VNC stands for Virtual Network Computing. It is remote control software which allows you to view and fully interact with one computer desktop (the "VNC server") using a simple program (the "VNC viewer") on another computer desktop anywhere on the Internet.
Your best bet would be to hold the reset button down at the back of your router for around 15 to 20 seconds. The router will then be back to the factory presets it was shipped with and should hopefully negate the problem.
Please let me know if this helps. Good luck!
Posted on Mar 01, 2008
How can i cascade a Comtrend CT-5621 with a Netgear Wnr2000v3
works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Jul 06, 2012 | NetGear WNR2000 Wireless Router
Tip
CASCADING / CONNECTING TWO ROUTERS (WRT54G)
To properly connect a second router to a main router that acts as the gateway, follow the steps below.
1. Try to isolate your 2nd router first by disconnecting everything from it and connect a computer to port 1. Make sure that the power cord is plugged in.
2. Reset the router.
HARD RESET- Reset the device to factory default.
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
3. From the computer open an Internet Explorer browser and type 192.168.1.1 on the address field. Leave user name blank and type admin on password, you should be at the Setup Page by now.
4. Click on Setup Tab and change the LAN IP/Local IP addresses to 192.168.1.2 then hit apply/Save settings. Note that, it won't go back to the Setup Page, close your browser.
5. Access the new IP address of the through Internet Explorer browser. Type on the address bar http://192.168.1.2. Look for DHCP Server under the Setup Tab. Disable the DHCP then click on apply/Save settings.
6. Shut down the computer and power down the router. Now get a cat5 straight-through Ethernet cable and plug one end to one of the four ports at the back of the secondary router and plug the other end to one of the regular ports on the Main router. Then turn both back on. The 2nd router should be ready to provide connectivity now.
Hope this help everyone.
on Jan 15, 2010 | Linksys Wireless-G WRT54G Router
I have 2 wireless routers cascaded with each other... looks like they are having a problem because of their IP address... how do I change the IP address of the 2nd router which is not attached to a...
Wired the 2nd router into another computer ( you only need the power and an ethernet cable into the #1 port of the router )
reset and power cycle the router. then type 192.168.1.1 into the address bar of your internet browser. type admin on the password field, leave the username blank.
-->if you like to setup the router as only an access point
  • on the setup page of your router, disable the DHCP server and change the LAN ip of the router to 192.168.1.5
  • go to the security tab and uncheck all the filters (don't forget to save the settings )
  • go to the wireless tab and personalize the wireless network settings
  • plug a cable into the ethernet port ( 1,2,3 or 4) of main router and plug the other end to the ethernet port on the 2nd router
  • power cycle everything and you should be good
-->if you don't want to router to act as an access point
  • just changed the ip to 10.10.10.1, save the settings
  • plug an ethernet cable into the ethernet port on the main router, connect the other end to the internet ( yellow ) port of the 2nd router
hope this helps
Sep 04, 2010 | Linksys Wireless-G WRT54GS Router...
How can i stop people from getting on my wireless router step by step please im new to all of this thanks ?treasacambalick@yahoo.com
Click Start-> RUN -> CMD . A Black windows will open. type ipconfig in that windows. Check the gateway address you are getting. Open Internet explorer and type the same gateway address in address bar on Internet Explorer. If asks for password type username and password - Admin. Or check according to your router manufacturer. Once open you will get Router page. Go to wireless settings and the security. Choose security type like WEP/WPA and then set password/Key for your network. Save settings in router page and then restart router. Search for available wireless network on your computer. try connecting to your network now it will ask you password. Don't share your network password with anyone and no one will be able to use it.
Aug 08, 2010 | NetGear WGR614 Wireless Router
I got into my Coolmax external hard drive on my computer, via internet cable and router. I got into the hard dirve OK. I am trying to get another 2nd computer recognized on the hard drive. The Coolmax...
Indeed, it sounds like a sharing problem. But, based on your explanation, I'm not sure what your issue is as your terminology is not standardized.
Example: you said, "I am trying to get another 2nd computer recognized on the hard drive." What would be more accurate, is that you are trying to get the 2nd computer to recognize the 1st computer so you can access the 2nd computer's hard drive.
On the other hand, you said the hard drive uses a network interface, and you have it connected to the router. So does it have some kind of web based interface? No, if what I read about it says that it uses USB 2.0 and eSATA, which means it is directly connected to the 1st computer, and so it would have to be shared to the 2nd computer via the 1st computer.
I also note you don't specify any operating system, which is absolutely required. Because, for example: Windows 10 has sharing problems; I'm a professional, and I haven't bothered till they fix it.
You said: "I registered the ID and password", which does sound like you're using Windows to set up a share. But then you say, "Did Run //storage/person" which means nothing to me. As that's not any way to set up a share that I'm aware of. (Maybe I'll learn something ;-)) And then you say, "2nd computer's hard drive was not recognized" and that's confusing, because I thought you were trying to see the Coolmax which is on the 1st computer, right? Or is it on the 2nd computer. So it's really not clear what you're doing, or what you think you're trying to do. If you clear this up, I'd be happy to see what I could do to help.
How to set up File Sharing on Windows 10
Jul 04, 2017 | Coolmax HD-211-eSATA Hard Drive
Hard wired router
First you must Share the printer.
On the seccond computer type in run windows \\computername\
After that you will see the shared printer
Feb 24, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
What steps do I take to allow my 2nd computer, a laptop, wireless connection to internet through my WGT624 wireless router?
>Switch on your laptop wireless..
>Goto Network sharing center from network connection settings menu from control panel..
>Search for New Connection and select your Wifi router And mark it as shared..
Aug 14, 2009 | NetGear WGT624 Wireless Router
I am looking for my wirless routers web key Im not sure where to look people sa I should look for the Admin Page but im computer dumb haha please help!
1. connect to router using cable (RJ45)
2. make sure NIC configuration is set to dhcp client
3. click start run and type cmd in text field press enter on keyboard
4. type ipconfig /all in black window and press enter on keyboard
5. write down ip address of Gateway should be somthing like 192.168.x.x where x = number between 1 and 254.
6 open browser type in address bar http://192.168.x.x/
7 if you are promted for a username and password check the default username and password on the internet for the make and model for the router if this does not work then reset the router by finding the reset button usualy at the back of the router and use a paper clip to depress the reset button for at least 5 seconds go back to step 1.
8 once connected to web interface on router look for wirless LAN, security you will then find the network key or passphrase depending on what type of security is being used.
Apr 15, 2009 | Computers & Internet
Trying to get online
Check if you are getting an ip address...there is a possibility that eventhough you are connected you are not getting a valid ip address. Are you trying to connect to the same network or same SSID?
Nov 04, 2008 | Belkin (F5D7230-4) Router (587009)
Connection
Using the main computer, open your Internet Explorer and on the Address Bar type http://192.168.1.1
It will prompt your for username and password. By default leave it blank on username and type admin on the password
Under SETUP tab, click the sub-tab MAC ADDRESS CLONE
Click on ENABLE and click the button CLONE YOUR PC's MAC then click on SAVE SETTINGS at the bottom.
Nowpower cycle your devices. Turn off router first and then modem. Waitfor 30 sec. Turn on modem first, wait for lights to stop blinking thenturn on router.
That's it. You should be able to share internet on all your computers that are connected to the router.
Aug 08, 2008 | Linksys Wireless-G WRT54G Router
NetGear WGR614 Wireless Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
