Wd 8013f Hi the washing machine will not power up? the circurt board was replaced last year as recall not shore if this has something to do with it.???
Try to replace the fuse..if still not power up.consult a certified service personnel.
Posted on Mar 01, 2008
Lg 7.5 WD-8013F had sparks and stopped working
Where do sparks come from. Motor is in back.
Mar 10, 2017 | LG WD-80130F
Hi there, I have an LG WD-8013F font loader washing machine that made a loud pop with a burning smell when I tried to run a wash program. I turned it off, and after a while tried the wash program...
semakan
  • memeriksa
  • menyemak
  • ')" onmouseout="ht(this)">check
    capasitor dalam tenaga
  • dalam kekuatan
  • ')" onmouseout="ht(this)">in power
    memasuki
  • masuk
  • memasuk
  • ')" onmouseout="ht(this)">enter
    that duduk di dalam')" onmouseout="ht(this)">staying inside.
    Nov 20, 2010 | Washing Machines
    Lg intellowasher wd-8013f is very noisy
    it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
    May 09, 2010 | Washing Machines
    You suspect right.
    It is a complete strip down job. I have just finished mine.
    taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
    Download the manual from LG.
    Good Luck
    Mar 17, 2010 | Washing Machines
    It doesn't let me choose a cycle - doesn't work
    the control pannel faulty needs replace ment. press the cancel/pause button and clean button together to reset the board.check it if gets reset then it will work orther wise replace control board.
    Mar 07, 2009 | LG Washing Machines
    Washing Machine LG WD-8013F
    it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
    Apr 03, 2008 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
