Question about EliteGroup PT800CE-A Motherboard
Memory upgrade causes system crash
PT800CE-A with P4 running XP Pro w/ SP2. Runs fine with one pqi MD441GUOE 1 gig. Crashes when I try to add another identical stick.
Any help is appreciated.
  • XrayJ Mar 01, 2008
    Thank you Sergio.
    I went to the manufacturer's site and found the downloads on this page:http://www.ecsusa.com/ECSWebSite/Downloa...
    I don't know which one to download. Please make a suggestion. Thank you.
  • 818 Answers
Is this memory that you have put ddr-400? if so upgrade the bios,the motherboard that you have choose have a lot of problem.
Suerte.
Sergio
Posted on Mar 01, 2008
Crashes to windows after playing about 5 minutes
Most likely the issue you are having is your computer is under powered to run both Vista Home Premium and the game. Vista is heavy on the resources and since you are running Vista Home Premium you will need more then some running the Basic version.
So the easy fix would be to up you memory upto 2 gigs. Note best practice for Vista is to have atlest 2 gigs of ram in the system.
If you still have trouble I would test the game on another Vista computer with a 2.0 or higher CPU to see if it still has trouble. If it does not then most likely it will not work on your computer.
Also if you did an upgrade from XP to Vista you might have so Windows issue. So if the test on the other computer worked you might try a fresh install of Vista to resolve any possible Windows issues.
Hope this helps
Issken
Sep 18, 2009 | Ubi Soft Capitalism 2 for Windows
HP Pavilion laptop freezes daily and i force manual shutdown
It sound's like there could be a compatibility problem, maybe corrupt file's, or missing start up file's, have you tried doing a window's update, or doing a disc check on the hard drive, go to my computer right click the drive then go to propertie's, click on tool's then click check now for drive error's. if that do'es not work you may need to reformat back to the original xp os.
Apr 16, 2009 | HP Pavilion dv1000 Notebook
Im not sure how much ram to use with my motherboard.
Your board can support 4Gb of RAM.
CLICK HERE for the SPEC sheet.
HERE is the memory support list, there is only 1 type of KINGSTON 2GB stick that is listed as compatible.
Make sure you have the latest BIOS as there are some known issues with this board and certain 4GB RAM configs as well as fixes for 1TB HDD space errors.
Always a good idea to make sure you have the latest XP service pack. In general, XP only recognises 3Gb RAM but mine runs fine with 4 in it.
When you crash, is there any Blue Screen of Death (BSoD) or any other output to your monitor or does it just shut down with no warning or error code or anything? If this is happening then you may be getting a CPU OVERTEMP condition.
Have you recently upgraded other components as well as your RAM?
Mar 26, 2009 | Intel Motherboard
Microsoft XP STOP OXOOOOOO7E OXCOOOOOO5 OXF78DA208 OXF78D9F08 - PCI.SYS add f748eobf base at F7487000,Datestamp 3b7d855c
If you didn't yet then upgrade to SP2.
Update drivers for all hardware, in most cases this is a driver conflict.
If that didn't solve the problem then scan for viruses with AVG.
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10320142.html?cdlPid=11006019
Scan for malware with Anti Malware.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?cdlPid=11004434
Scan for broken registry entires with Registry Mechanic.
http://www.download.com/Registry-Mechanic/3000-2094_4-10190447.html
Let all 3 software repair/remove the errs they find.
If the problem is still not solved then reseat the memory stick to another slot, since 7E with nt status code c0000005 (access violation) could be caused by faulty RAM. Clean the dust inside the PC.
If it still crashes, downclock the RAM.
If it does not resolve the problem, replace the RAM.
Feb 21, 2009 | AOpen P4/2.4 40GB 512MB XPP...
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
XP-Pro Crash
I don't know why but some systems which have XP (SP1 or SP2) simply can't take the upgrade to SP3. Your system appears to be one of them. For instance our family's computer had XP SP2 and upon upgrading to SP3 we received a fatal crash while XP was loading into normal operating mode.
I managed to resolve the issue by booting to safe mode and restoring the system to a date before I installed SP3. Sorry that the new SP doesn't work for you.
Feb 03, 2009 | Microsoft Computers & Internet
Toshiba A105-S2101 keeps crashing!
try downloading and running memtest86 on it, my guess is that the new memory chips are faulty.
Dec 04, 2008 | Toshiba Satellite A105 Notebook
Soltek KT-600-R and SP2
Have you tried a Motherboard Bios Firmware Upgrade? It should be readily available on the Manufacturers Website.. There are a number of diagnostics you can do to pin-point the actual malfunctioning component, rest assured everythings stable with the softwares being used and the OS environment is virus/spyware free! you can 1st upgrade the Bios to the most latest (Non-Beta) version.. If that doesn't help, try a single 512mb Memory Stick, one by one and notice if that helps with the (BSOD) errors..
Mar 15, 2008 | Computers & Internet
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
Unanounced system shut down
The next step that I would recommend is to use the Admin Tools in the Control Panel and select Event Viewer. Check out each of the three logs and see which one has an event with the red X at the time of the shutdown. High light it, and you should be able to see what program, if any, caused the problem. That should give you more information that may be more specific and help you track down the actual culprit.
Jan 30, 2006 | EliteGroup PT800CE-A Motherboard
EliteGroup PT800CE-A Motherboard Logo
106 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
