Question about NetGear RangeMax Next Wireless Router Bundle
How go I axcess my wireless router from my laptop
I need to change my WEP setting any I did an "ipconfig /all" in my comand prompt and I cant find my ip address for this pc to log into my router. If there is another way to obtain this information please let me know.
  • 57 Answers
Try going here, mate. Really not enough info to go on.
http://www.informit.com/articles/article.aspx?p=461084
Hope this helps and luck!
Posted on Mar 02, 2008
Belkin N300 Surf problems
The router has to be manually configured in the gui page within it to allow remote wireless access point. This is not done by default as a security feture on routers. The way to find out the ip address of the router to set up a wireless access point or remote configuration is to go on your machine that has active working internet and click start, all programs, accessories, right click comand prompt, select run as administrator, confirm, then once in comand prompt admin, typ in ipconfig /all, then look for default gateway in the first list shown this is the ip of your router. Hope this helps.
Sep 03, 2012 | Belkin Surf N300 Wireless N Router
Where do i find my wep key
Your WEP key, assuming it hasn't been changed since you got your wireless router, should be printed on a label on the router itself along with the router SSID that identifies your network when you see it in the list of available wireless networks to connect to.
If the key has been changed, then you would need to access the Admin web interface of the router and sign in to that in order to check what the current security settings are configured as.
The Admin web address is normally the same as your default gateway address and DHCP server address as shown when you open a Command prompt window and type ipconfig /all
Jan 11, 2012 | Toshiba Computers & Internet
I need the WEP key code to setup a new laptop
Hi, IF you want to get the WEP key for the wireless for the new laptop, you need to access the computer that is currently connected to it. then you need to co go command prompt by click on start > type in the start search box > cmd > then command prompt will come up > now you need to type 'ipconfig' and you need to get the numbers for default gateway. Next is you need to open Internet Explorer, then type in the default gateway on the address box. And you will be shown the interface of the router. Just look for the Wireless settings then security and you should be able to get the WEP key you're looking for.
Thank you for using FIxya. Your recommendation is highly appreciated for the free support.
Jul 21, 2011 | D-Link AirPlus DI-524 Wireless Router
I need a pin number from my linksys Router in order to reset it to make it a WEP-2 Personal so that all my neighbors stop stealing my internet.
cant say i have used this router however:
RESET to DEFAULT IP Address, Password
Set router POWER ON.
Reset router: With a straightened paperclip, press RESET button 15secs.
Wait 60 secs.
PC Command Line:
Click [Start] - Click [Run...] - enter: cmd, Click [OK]
At the prompt (c:\.....>) enter: ipconfig /release, press [ENTER]
At the prompt (c:\.....>) enter: ipconfig /renew, press [ENTER]
TEST: Open Web Browser: Connect to http://192.168.1.245
Username: [blank] or admin
Password: admin
Jul 11, 2011 | Linksys Wireless-G WRT54G Router
Trying to connect another laptop to our wireless internet have forgotten security key password
try to access router page and get it from there.
you need your default gateway start>run>cmd
on command prompt type ipconfig press enter look for default gateway and put it on internet explorer for the address page eg.192.168.1.1
Mar 23, 2011 | Computers & Internet
Wireless security settings are set to wps. Where can I check out the wireless security password to connect another laptop(mac) wirelessly?
What kind of router do you have? Generally you can connect to the router through a web interface. You can find the IP address of the router using the steps below (assuming that you're running Windows)..
1) Click Start
2) Click Run
3) Type in 'cmd'
4) Click OK
5) In the command prompt window type in 'ipconfig'
6) Hit Enter
You will then see the default gateway. Open your web browser and go to http://the.default.gateway.address (replacing the.default.gateway.address with the IP address shown from the ipconfig command). You should then be prompted for a username and password. Most routers by default have a username of 'admin' and a password of 'admin'. If your able to login with that you should have a wireless option or wireless security option where you can go to retrieve the key or at least change it.
Mar 05, 2011 | Computers & Internet
Can't hookup to d-link
1.check your wireless setup and see if the wireless is on.
2. Do ipconfig / all at the DOS prompt on the laptop
3. Test the router by setting up the laptop by MAC address.
4. Go into security settings ( router) an create key( WEP/WPA )etc. Don't do this step until it all work properly.
May 16, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I need a wep key for my ds but cant find it
-Go to Start-> Run
-type "cmd"
-at the dos prompt type "ipconfig /all"
-get your default gateway ip
-Go to your browser like Internet explorer.
-Type in that ip xxx.xxx.xxx.xxx.xxx
-That is your router setup where you can find the key or change it
-hope that helps
Jun 03, 2009 | Packard Bell (181379) Motherboard
Security
ok , you need to set up a WEP key
so only u fam. can connect dont want pirates
ok go to ur command prompt and type in (ipconfig)
vista command prompt is on (all programs | accessories | then command prompt )
in xp go to ur start then RUN menu type (cmd) and run
should pop a black screen
type in (ipconfig) and hit enter
get the default gateway no.
enter that on ur address bar and go in ur router
go to ur wireless settings and make a WEP code
****if any pc in home is connected to wireless might be prompted for key code type the wep code u made and that should be it
,JULY
ps rate my service please
Apr 11, 2009 | Belkin (F5D7231-4) Wireless Router
Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Feb 13, 2007 | NetGear WGT624 Wireless Router
NetGear RangeMax Next Wireless Router Bundle Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
