Question about Car Audio & Video
Pioneer XR-P2500C Display Does Not Light
I got my mini component stereo back from my brother in law and after some time in his garage the digital displays no longer light up. The leds on the board do but not the LCDs. The unit functions ok but you just can't tell what track is playing on the CD or what radio station it is tuned to. I figure it must be something simple but I do not see any blown fuses or unplugged harnesses. It is pretty dusty inside. I will try to clean it and see if that helps. Any ideas other than that? Thanks!
  • Anonymous Jul 14, 2008
    My buttons don't work, cd plays but iit's stuck at low volume.
SOURCE: display problems
its the ribbon cable that goes from the facia to the headunit
Posted on Jun 28, 2007
simplemitch
  • 752 Answers
SOURCE: Error ao pioneer head unit
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Posted on Aug 04, 2008
  • 55 Answers
SOURCE: Changing the time
I don't own a pioneer cd unit, but you can go to pioneerelectronics.com and download one for your particular model. Hope this helps...
Posted on Aug 30, 2008
SOURCE: alpine cda7969r display problem
Hi trinder,
I fixed my Alpine TDA-7563 with the same problem. My display was completely blank everything else worked. After checking that the LCD display is getting power and everything else in the face that I can think of, I thought maybe the rubber LCD contacts were squeezed down or something and not making proper contact, so I just pushed it back onto the board and pressed.
This was at night, so I had an external lamp and noticed to my delight that the display was in fact working, nothing is wrong with it.
I am embarrased to say that as a technician I forgot that an LCD display needs a backlight, duh.
So a simple connectivity test on the 2 lamps shows that they are both blown.
I have to source them at my local electronics store, I measured the power supply to them as 12Volts, so it is just a matter of getting ones with the right dimensions and bright enough.
Hope you have the same problem, then it will be an easy fix for you.
Good luck,
Ramesh
Posted on Dec 14, 2008
SOURCE: Error Codes
I've had a friend to stay who had this problem. I downloaded the user manual from the internet and the error code is not mentioned. I followed the procedure to reset the radio and this solved the problem.
Take the cover off the stereo and locate the small hole (towards the centre) which houses the reset switch. Insert something like a paper clip into the hole and hold for a few seconds. Then replace the cover and all should work. You'll loose all the radio presets.
Posted on Feb 17, 2009
Tip
How do i connect my iPod to a Pioneer Car Stereo
<p>It is advisable to listen to your iPod through headphones while driving in the car. Not only is it dangerous to completely cancel the sounds of the road as it is often illegal in many cities across the country. There is an alternative, however. In just a few steps you can use your iPod to your car stereo speakers and use the car to listen to your music, podcasts and audiobooks. No brand car stereo makes it easier to connect these beautiful than Pioneer. <br /> <p><br /> <p>1. Connect one end of the mini-jack on your iPod headphone jack. Once done, set your iPod or on your dashboard or your car seat so that it will not tip over while driving. <br /> <p><br /> <p>2. Find your sound system's auxiliary input Pioneer. It is often located in front of the front panel stereo, but can also open the front or back of the unit completely. If the extra connector on the back of the stereo itself, then you remove the panel. When it comes to this, see the instructions that came with your sound system is provided for further guidance. <br /> <p><br /> <p>3. Connect the other end of the cable mini-jack for stereo aux port. This will allow your iPod to the audio signal through the cable to the stereo and the stereo signal will pass to the car speakers. Most often, when something is plugged into the stereo aux jack will work in stereo. In some models a setting to select the additional connection. Whatever the case, now you can sit and enjoy your iPod for that long car ride. <br />
on Aug 09, 2011 | Apple iPod touch
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
Unit is always shutting down / turning off
Try first unplugging power cable for five minutes and using a different power outlet, if you still get the problem, the unit has a faulty power supply on the board inside.
Nov 12, 2008 | Pioneer Televison & Video
I have a AIWA XR-MDS7 EZ sup mini stero unit, the lcd display is dead although the unit works I cannot tell what disc is playing or track number. Also I cant tell what radio station is playing. Everything...
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Dan
Apr 11, 2008 | Audio Players & Recorders
Changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Dec 25, 2007 | Pioneer DEH-1500 CD Player
Time set
How to change the time on a Pioneer DEH 1500 car stereo:
With the radio off, select the 'clock' (upper left button) to display the time.
Press and hold the 'audio' (upper right button) until the time display blinks.
Use the 'select' buttons to select the hour or minutes and adjust time (right button selects minute digits, left button selects hour digit, up button increases the time, bottom button decreases time). Comment by dognut, posted on Dec 25, 2007 Just a further comment posted by dognut:
After setting the desired time, 'press any
Oct 25, 2007 | Pioneer DEH-1500 CD Player
Car Audio & Video Logo
240 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
