Question about Hyundai Electronics ImageQuest N91S 19" LCD Monitor
2nd hand hyundai n91s monitor
Please help ,got hold of a monitor above, connected the power and pc end this also has a phono green mini jack plug wire, were does it go, as the input for the green connection is already taken by my sound system, also theres no visual only the blue power button illuminates. do i need a driver to install on my vista home premuim, as its hard work to install anything on vista if your missing the set up disc, thank you mr foster.please send me a download site.
  • 151 Answers
You can et driver from
Posted on Mar 01, 2008
Yes, you can. Go to a local electronics store or go online and buy a cable (we used to call them patch cords back in the day) with a 1/8" STEREO plug, (also called a mini phone plug) on one end and two phono plugs (also called RCA plugs) on the other end. They're available in various lengths -- 12" is a good choice. We're talking less than $10 here.
Connect the RCA plugs into an appropriate pair of unused INPUT jacks on the back of your receiver -- CD, VCR1, Tape Monitor/VCR2 will do. DO NOT use the phono jacks. The red plug is for the right channel. You can leave the cable plugged in. Then whenever you want to listen to your iPod, insert the mini phone plug into the iPod's earphone jack, switch the receiver to the input for the cable, and start playing. You may have to increase the volume on your iPod to avoid having to turn the receiver all the way up (or down) to listen, but after that you can use the receiver's volume control.
Oct 28, 2014 | Panasonic Technics Sa-gx130 Receiver...
I am unsure what cable to use to connect the audio system to my monitor. I have a cable that has a green round connection on one end and a purple round connection on the other. Is this the right cable? ...
If your monitor has built-in speakers, then you can connect the audio
output (stereo mini plug) from your computer to the monitor. Look
at the back of your PC, there is a light green Jack: that is the Audio
Output Jack (Consult your PC user's manual for verification)
Here is what your cable should look like:
Jul 17, 2011 | Computers & Internet
I don't see any connection to hook up speakers
the vga monitor cable also carries the audio - there is a 3.5mm jack on one end of the cable that plugs into your speaker socket
Apr 16, 2011 | Hyundai Electronics ImageQuest N91S 19"...
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
How can i get the computer sounds to play thru the built-in speakers of polaroid flm-1507
You need a cable with mini-phone plug at both ends (Radio Shack), one end is plugged into the monitor audio input jack (Green), the other end will be plugged into the PC audio line out jack (Green).
Dec 16, 2010 | Polaroid 15'' HDTV Monitor FLM-1511
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
I need a diagram showing me how to wire a 3.5mm mini jack (input)? Its for aPC Audio Cable.... seems there are no experts who can help as its not in the "products".... plz forward this to someone who might...
A any jack/plug it is always wired the same, there are only 2 wires, + Plus, and - Negative, ETH, GND. The Minus, GND, ETH, always, logically, goes to the or Negative or "Case" ETH, Gnd, all mean the same. Now the + Positive is always Plus,. If the connection is for a Coaxial Cable then, the inner core is Plus +, and the Shield is always - Negative, Gnd, Earth. All Jacks and Plugs wire the same. With a Phono MONO Phono Jack, the "Bulb End" is always Positive, the Case or Outer is - Negative. IF it is a Stereo Plug/Jack there is simply, Two Plus wires, and two - Negative, Eth Wires, these Two, Negatives, Earths or Contact together, and go to the Outer Connection or Negative. The Two + Plus Wires go, One to each tip connection, of the Two Positive connections, that go to the end, Bulb Tip A & Tip B, of the Stereo Jack./Plug
For Power Connections the same is generally true, the Centre Conductor is usually Positive, while the other one is - negative, case, eth gnd.
Feb 18, 2010 | Polk Audio IBM PC 300PL Mini Tower...
Monitor's audio out not working
You need to connect a line out from your PC audio card (green mini stereo phone jack) to the monitor audio line in jack (green mini stereo phone jack)
Feb 16, 2010 | Computers & Internet
Monitor Hyundai N91S
please reinstall your motherboard cd once again if not upgrade your graphics card...
Dec 31, 2007 | Hyundai Electronics ImageQuest N91S 19"...
Hyundai Electronics ImageQuest N91S 19" LCD Monitor Logo
275 people viewed this question
Top Hyundai Electronics Computers & Internet Experts
David Payne
David Payne
Are you a Hyundai Electronics Computer and Internet Expert? Answer questions, earn points and help others
