Question about Kenmore 72073 Top Freezer Refrigerator
Constant build up of ice on the freezer lower shelf
We seem to need to defrost every month or so because ice builds up on the shelf of the freezer on top and then melting ice water flows into the refigerator.
We are careful to not leave the freezer open.
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 01, 2008
I have a Kenmore upright freezer there is ice built up along the top and upper/lower shelfs what could be the problem
Ice build up is usually a tell-tell sign of a defrost related problem.
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts
Jan 29, 2017 | Kenmore Refrigerators
Build up of ice at back of freezer
how old is this unit? try lowering the temp a few degrees also have you done preventive maintenance to this unit?
Dec 16, 2013 | Neff Refrigerators
Csx22br freezer ice build up water runs out bottom of freezer
Your defrost drain hole may be plugged or frozen over. Open the freezer door and remove the lower shelf and basket so you can get to the back evaporator cover, and right under it is the drain hole. Remove what ice may be built up and pour very hot water into drain. It helps to have a syringe to remove the water and pour more hot water into drain. Then use a wire or other flexible tubing to poke into drain to clear restriction then flush with water.
Oct 30, 2011 | Hotpoint Refrigerators
I get ice build up in lower shelf of freezer and water leaking into top shelf of refrigirator What should I o?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Whirlpool Refrigerators
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Freezer cold ice building up fast lower part of fridg is warm
Your defrost system has failed. Replace the defrost thermostat,defrost heater and defrost timer.
Jul 07, 2009 | Refrigerators
Ice build up on back wall of freezer
You need to replace the heating elements and defrost timer relay. Had same thing as you 6 months ago. The lower one is probaly blown but replace all 3 parts or youll continue to have problems.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Jun 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water build up in the freezer
When your refrigerator defrost the condensation has no place to exit to because of a restriction in the drain and that could be water that has turned into ice or possiably a food partical or foreign object. Defrost it compleatly by leaving freezer door open for aprox. an hour at least make sure ref is level front to back an d you should not have this problem anymore. Please rate me and let me know if this helped. Thanks
May 22, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool refrigerator with top freezer either model GR2 or 9FHTXT will not keep get cold
Sounds like the defrost drain has become iced over or clogged. This is why the ice builds up.
Jan 14, 2008 | Refrigerators
Kenmore 72073 Top Freezer Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
