Question about Cuisinart CPM-800 Popcorn Maker
Popping plate not heating up
My popping plate is not getting hot. The stirring rod is rotating so I assume the plate is locked in properly, however after several minutes (10 +) of stirring, the plate is still cold. Could there be something wrong with the unit? It worked the first few times I used it.
  • 2 more comments
  • Anonymous Jul 19, 2008
    I have the same problem with my popcorn maker not heating up.
  • Anonymous Oct 18, 2008
    I am having the same problem POS
  • Anonymous Oct 26, 2008
    ditto!
  • Anonymous Oct 28, 2008
    Same exact problem for me -- this is only third time I've used it!!! It's only 10 days old.
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Posted on Nov 21, 2008
    Scholar:
  • 148 Answers
Place an enamel-coated cast iron Dutch oven (such as one from Le Creuset) on medium-high heat. Add 1 teaspoon vegetable oil and 3 popcorn kernels. Cover it and let it heat up. Don’t shake it or anything. Wait until the three kernels pop, then pour in 1/2 cup popcorn. Stir to coat kernels in oil, then cover and leave the whole thing alone. When popping slows down to one pop every few seconds, remove from heat, uncover and pour into serving bowl. Cue melted butter and salt. Eat.
Posted on Mar 04, 2008
Popcorn popper isn't popping popcorn
If it heats up, your popcorn may be old and dried out. If it doesn't heat up and the stirring rod does not turn, check your power cord for defects. Procedure: plug in the popper (check both ends of the cord!), turn it on, and gently wiggle the cord right at the plug or where it goes into the popper, and watch the stirring rod to see if it moves. If it starts and stops as you wiggle the cord, you've found the break in the cord. Repair it or replace it (West Bend lists it online for $5) and be more careful with the cord in the future (never unplug by yanking on the wire, always pull on the plug itself).
If the stirring rod turns and there is no heat, the thermostat or thermal fuse is probably open. This can happen in some poppers if the air vents are blocked on the bottom. Remove the obstruction from the vents, let everything cool off, and try again. If it does not heat up from a cold start, there may be a blown thermal fuse inside. If you decide to replace the thermal fuse or thermostat, it MUST have the same temperature and current rating as the original.
Jun 17, 2016 | West Bend Westbend Popcorn Popper Stir...
Corning Pc-320 hotplate/stirrer. Where can I get a manual?
Why do you need a manual there is nothing to do. To make the stirring function work, you need a magnetic stir bar (just a Teflon coated magnet. There is a motor-powered spinning magnet under the ceramic plate.
The heater is not thermostatically controlled. It just heats more as you turn the dial more.
May 17, 2015 | Corning Pc-320 Laboratory Stirring Hot...
Sunbeam microwave not heat
Place a glass pie plate in the oven with about 1/8" deep water in it. Turn the oven on high for about 30 seconds. If you get one small spot with intense boiling, the stirring antenna at the top of the oven is not rotating. It's usually driven by a small 60 RPM synchronous motor. To get at it, look for a pull-out plastic locking pin that holds the plastic dome or plate to the tope of the oven cavity. You may need to rotate the cover counter-clockwise a fraction of a turn to unlatch it. Sometimes greasy food vapor gets in there and gums up the bearings. Clean very thoroughly, but be careful not to bend the antenna blades. When you reassemble, make sure the antenna is properly seated in its bushing and engaged on its drive shaft. Repeat the test to see if you have even heating.
If you see no evidence of heating anywhere in the oven, check to see if the door switch in series with the transformer is malfunctioning. If the door switch is OK, you'll need a high-voltage measurement probe to determine whether the magnetron has failed, or (more likely) the high-voltage capacitor or diode is bad.
Apr 15, 2014 | Sunbeam Microwave Ovens
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
What is a hot plate stirrer?
From Wikipedia: A magnetic stirrer or magnetic mixer is a laboratory device that employs a rotating magnetic field to cause a stir bar (also called "flea") immersed in a liquid to spin very quickly, thus stirring it. The rotating field may be created either by a rotating magnet or a set of stationary electromagnets, placed beneath the vessel with the liquid. Since glass does not affect a magnetic field appreciably (it is transparent to magnetism), and most chemical reactions take place in glass vessels (i.e. see beaker (glassware) or laboratory flasks), magnetic stir bars work well in glass vessels. On the other hand, the limited size of the bar means that magnetic stirrers can only be used for relatively small (under 4 liters) experiments. They also have difficulty dealing with viscous liquids or thick suspensions. For larger volumes or more viscous liquids, some sort of mechanical stirring is typically needed.
May 01, 2013 | Science & Laboratory
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
I purchased the stir crazy model 82306 and it does not pop the corn properly. Less than half of it pops. I have never had this problem with other West Bend stir crazy poppers in the past. On 4 separate...
I have one of these poppers and have been impressed with the minimal number of unpopped kernels.
On only one occassion have I not been satisfied and suspect it was due to insufficient oil being added.
Make sure you are adding sufficient oil to aid heat transfer to the kernels.
Jan 16, 2011 | West Bend 82306 Stir Crazy® Popcorn...
Stirring rod stopped
Hey,
The stirring rod is operated by a motor on the bottom of the popcorn maker, if the rod is not moving, it means the motor is not moviing either. Most likely faulty motor, and it should be replaceable by opening the bottom of the maker. If the motor rotates but the rod doesn't move, something is cut in between the motor and the rod.
Thanks,
Ekse
Aug 07, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Cuisinart CPM-800 Popcorn Maker Logo
786 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
