Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite He5t front load waher
When I ty to do laundry an F30 error signal comes on and the machine is making ticking sound.
  • 3 more comments
  • Anonymous Mar 29, 2008
    I have a Kenmore Elite H3 5t that doesn't fill up with water. When it's at the point where water would start to fill the washer, you hear a ticking sound. I did see a F 30 error show up once, but now it just keeps ticking. I tried unplugging it for over 30 minutes, problem did not go away.
  • Anonymous Mar 30, 2008
    I have the same problem is this caused by changing laundry detergent
  • Anonymous Aug 23, 2008
    I had the same problem, I pulled out the detergent tray out and hit the reset inside towards the back up on top & worked. Thanks
  • bing5591 Nov 23, 2008
    I don't seem to find the "reset" button. Can anyone help please?
  • Scott991 Dec 02, 2008
    Same thing here. I don't seem to have this flapper switch. There is a rotary thing in the back that won't move. Perhaps it's been redesigned?
    Scott
  • 3 Answers
Hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
Posted on Aug 09, 2008
Hi Everyone,
Where is the "spring board wheel"? I reach to the back end the opening. There is something on the top, but it can't be moved or turned in any fashion. Is that the "reset devise" you guys were talking about?
Please help.
thank you in advance.
Bing
Posted on Nov 23, 2008
  • 113 Answers
The computer needs to be reset unplug washer for 15 minutes then plug back in.
Posted on Mar 05, 2008
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
Softener does not dispense and we get a code F 30
This error code F30 flashes when the central control unit (CCU) cannot drive the dispenser motor to the proper dispensing position and hence the softener dispensing problem. Disconnect power then remove the top panel and check the dispenser motor assembly for damage or broken parts. You may run a diagnostic test then take a look at the dispenser motor and observe how it behaves. Replace the dispenser motor assembly if damaged.
Click on the link below for the troubleshooting details of this problem and instructions on how to run a diagnostic test.
Troubleshooting Error Code F30 on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
We have a Kenmore HE5t that has an F30 error code. When you start the washer it just keeps clicking and won't fill. Any advice?
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 11, 2010 | Kenmore Elite HE5t Washer
Kenmore elite 49962 washer error code f30
hi sir, please check the following link. it tells about cause of the problem[Error Code F30]. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
kindly rate me.. thanks for using fixya..
Feb 11, 2010 | Kenmore 49972 Front Load Washer
Kenmore elite washer he5t error codr f21
remove bottom panel 3 screws 7mm get bucket and alot towels, turn pump filter clockwise and remove all debris from inside pump now close it up nice and tight should solve youre problem
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
570 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
