Question about KitchenAid KHTU165RSS Stainless Steel Kitchen Hood
Kitchenaid downdraft retractable vent
My retractable vent just stopped working. I did not replace or adjust the vents. I used it one day successfully and the next time that I pressed the button for it to turn on, and nothing happens. I have checked the electrical connection and it is working fine. Any suggestions?
  • prinkas Aug 25, 2008
    My KitchenAid Retractable Downdraft Vent Systemn Model KIRD801 keeps going up and then down whenever I push the button. It will not stay up. I tried numerous times until now when it is stuck halfway - won't go up, won't go down and the blower won't turn on. I can hear the motor running. I turned off the breaker to stop the motor from running because I was afraid of what might happen if I left it running like that. How do I fix this?
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Posted on Feb 03, 2010
  • mattdoc160 Apr 29, 2011
    Mine was installed for 2 hours. Went up and down twice fine. The third time it went up and stayed on, with the hi/lo switch not working. Tripped the breaker to turn it off, now it wont do anything...stuck up. help?
    Sergeant:
  • 288 Answers
Check for power going into the switch. (you need a meter) If the switch is set to "on" there should be power going in and out. Find a good ground or use the white wire to test. If there is, just follow the path of electricity. If you do not have a meter this is next to impossible to do.
Posted on Mar 06, 2008
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
How do I fix KitchenAid Retractable Downdraft Vent System?
No model number but they are pretty much all the same you have a failed micro switch behind each filter screen is one rarely see them go bad but filters have to be in place for unit to work, depending on model there are either two or three switches around the motor they are pretty aggravating to get to they are located in the panel below the cook top some models require the removal of the blower motor and housing and depending on the install still my not be able to remove the main panel if you can get past all of this to the switches don't waste time testing them just change all of them they get grease in them which won't allow the contacts to mate
Jan 23, 2015 | KitchenAid Dryers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Downdraft vent won't stay down. Push the button and it retracts normally, then pops right back up?
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Aug 27, 2009 | KitchenAid KIRD861HSS Kitchen Hood
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
Kitchen Ranges Logo
3,398 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
