Question about Bosch Classixx WVF 2402 Front Load Washer/Dryer
Spin dry not working at times, clothes are very wet
I I have to respin my clothes about 1 out of every 4 washes. I am not sure what I can do to fix this. Thanks
    Problem Solver:
  • 8 Answers
Hello nordic sounds as if you have a intermitant pump problem . i.e blockage . disconect from mains - remove pump - dismantle pump look for obstructions. also check waste hose as they tend to block fairly easily when machine is used mostly on a low temp wash . good luck
Posted on Mar 01, 2008
Clothes come out of washer wet
Most often you have a worn out belt that spins the drum when it is time to spin dry. Upend the machine and check the belt, if it has one.
A new drive belt should fix you right up.
Mar 14, 2016 | Washing Machines
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
Whirlpool gold ultimate care ii
Possibly motor coupler joining motor to transmission or maybe transmission part (clutch, basket drive, transmission itself, drive block, etc)
Aug 22, 2017 | Whirlpool GSX9750 Top Load Washer
My amana isn't washing away all the bleach in 1 load
try and make sure your filters are not blocked ,therefor retaining some of the bleached water in you washer when you wash other times
Jul 20, 2012 | Amana Washing Machines
Washer will not turn on
HELLO.
BELOW ARE STEP BY STEP GUILD LINE ON HOW TO FIX THE PROBLEM OF THE WASHER
Nothing is more annoying when washing your clothes then finishing loading your clothes, only to find the machine is not turning on. There are a few different culprits behind this problem, most of which do not require you to purchase any new items to fix the situation.
1 Inspect the cable running from the washing machine to the electrical outlet to make sure it is connected to the washing machine properly. If the cable is cut or damaged, you need to replace it before performing your next wash load.
2 Find the fuse in the circuit breaker and make sure it is still active. You may have blown a fuse at one point using the washing machine, causing it to not run or turn on. Reset the circuit breaker by identifying the washing machine's circuit (it is written next to the breaker itself) and push the flip switch back in the opposite direction.
3 If you need to change a blown fuse, pull the current fuse out of the circuit breaker. The metal filament inside will be either black or burned through. Find a replacement fuse of the same voltage (the number is printed on the front of the fuse and found at any home improvement store), then insert the fuse back into the fuse's location inside the fuse box.
4 Remove any clothing that is blocking the washing machine door from closing completely, such as sleeves or pant legs tucked in by the joints of the front swinging door.
5 Contact your local repair company if the washing machine is still not working correctly. There may be an internal problem with the machine you cannot see.
Thanks.
Sep 29, 2011 | Kenmore HE2 Plus Front Load Washer
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Not spin drying the clothes
check to make sure the pump is not restricted or drain hose kinked.
May 20, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
The machine washes fine, but adds water on the drying cycle
The machine sounds faulty. You can bypass this by turning off the tap and respinning the clothes until the machine is fixed properly,
Oct 19, 2009 | Washing Machines
Bosch Classixx WVF 2402 Front Load Washer/Dryer Logo
87 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
