Question about Technics SA-EX700
Receiver problems i just hooking up my receiver after moving and it continues to turn itself off after 2-3 seconds, what can i do to fix it???
  • vickers0000 Mar 11, 2008
    KR-794 receiver. It shuts off after 3 seconds.
  • Colin L.Swan May 11, 2010
    What type of receiver please?
I think that is the cooling fan...good luck
Posted on Aug 22, 2008
  • 71 Answers
Sorry can't really think what 's going on here!!!!
I can only suggest checking once again that everything is connected up correctly and there is no possible 'overload' function operating that you have not spotted.
Check in manual/handbook or e-mail the problem to the manufacturers customer services e-mail ( see their web-site ).
Good luck with your bold attempts to rectify this annoying problem!!!!!
Posted on Mar 11, 2008
Receiver turns on for 2 seconds and then turns off itself, tried on different power sources but problem persists.
Short circuited component/s at its audio output stage circuit. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 18, 2015 | Yamaha RX-V757 Receiver
AVR 270 Receiver turns itself off immediately
Disconnect all speakers from Zone 1 and see if it stays on. If it does, you have a short on a speaker (probably cable). If not, you might have a blown output transistor on Zone 1. I have a DENON that I am fixing that does this, but only when I turn up volume. Creepy. Good luck !
Jan 22, 2014 | Harman Kardon Audio Players & Recorders
The 3 front speakers have started to buzz. When I unplug them in moves to the rear 2 speakers. I orginally thought it was the speakers so I got new ones, same problem. Not sure if it is my reciever getting...
This is a grounding issue either between pieces of equipment or inside the receiver itself.
There are other possible causes, but this will almost always be a grounding issue.
I recommend unplugging everything and hooking it up piece by piece till the buzz return to isolate the issue.
IE - start with nothing but the receiver and speakers hooked up. Turn on the radio. If the speakers buzz, the receiver has an issue and needs to be repaired or replaced.
If there's no buzz, hook up the DVD player. If the buzz returns, there's some issue between the DVD and the receiver....
If the buzz hasn't returned, hook up the.....<insert name of next piece of equipment here>
you get the idea.
Feb 21, 2011 | Audio Players & Recorders
My directv D11 receiver continuously resets itself every few seconds, how can I fix this? I have reset it via the reset button several times and it makes no difference at all.
Unplug the box from the electrical outlet and wait 30 seconds. Plug the unit back in. If the problem persists, you have a faulty unit.
Feb 15, 2010 | Directv D11 DTV Receiver
Sony Model: STR-DG800
You've got a short in one of your speaker wires either at the receiver (most common) or at the speaker itself. you should only have a 1/2" of each side of the speaker wire stripped to put on each terminal, and when you strip them, twist them so there are no frays in the strands that will touch the other terminal. The receiver is protecting itself from harm. Turn it off then disconnect all speaker wires, examine each wire carefully before reinstalling, then turn the receiver back on. If it still says protection, look at each speaker and reconnect your wires the same way. If you still have a problem, disconnect the wires again at the receiver and turn on, at this point, if it say's protection, it needs to be serviced. Hope this helps
Jun 23, 2009 | Sony STR-DG800 Receiver
Turn on Pc, Continually beeps 6 times then shuts down
it seems that your memory card is out of place. open the pc, reseat the memory, and that should be ok.
Jun 15, 2009 | Dell Dimension 3100 PC Desktop
Alpine CDA-9830 off-n-on mode
check all the power connections it could be that the remote wire is hooked up to somthing falty, try hooking it up with the positive power to see if that fixes the problem, useing this method will require you to have to turn off your stereo manually. the power wire is yellow and is usually thicker and the remote or (ignition) wire is red, just wire them both together. the remote wire is usually connected to the positive end of somthing that turns on when the ignition is on like the cigarette lighter. if thats not the problem it could be that its not getting enough power ether because the power wires going to it are to thin or there isn't a good connection. check the voltage at your battery and at your stereo.
Oct 28, 2008 | Alpine CDA-9830 CD Player
Auto shut off after powering on
please confirm your hooking is fine and try with good cable-make your volume master to minumum.and disconnect all speakers if the trouble goen you have a problem in your speaker and its cables.
if the problem remain the trouble will be in your system itself.and need to be fix in workshop.
Feb 24, 2008 | JVC TH-M303 System
172 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
