Question about SanDisk Sansa Clip MP3 Player
Problem with Right/Forward Button
I use my Sansa Clip to listen to audiobooks. When I lose my place and end up at the beginning and try to advance back to where I stopped listening, the player jumps to the next section. I am sometimes able to advance a little way into the section by holding the button down per instructions, but if I try to go further, when I release the button, it goes to the next section. This also sometimes happens right from the getgo. Is this a problem with my particular player or am I doing something wrong.
I am embarrassed to admit that I finally looked at the brochure that came with the Sansa Clip and called the Tech Help number. The person I spoke with was very helpful and walked me through the process of re-formatting my Sansa Clip and downloading an update program. This solved my problem. I think the issue was my computer operating with VISTA while the Sansa Clip was set up for XP.
Posted on Mar 02, 2008
I recently purchased a Sansa Clip MP3. I downloaded audiobooks to it but they will not play. What do I need to do?
Not true!!! The Sansa Clip is actually the best mp3 player I have found for listing to audiobooks. Here is what you need to do. Download the latest firmware update on the Sandisk website. You must do this or it just won't work unless you are downloading books from Audible.
I use the Overdrive Media Console and download mp3 and WMA books from my state library. When you hit transfer, be sure it hit advanced options. Browse until you select the audiobook folder on your player. Then transfer to that.
The player will bookmark your last place on anything that is in your audiobook folder. You can easily switch back and forth between your music and book without losing your place! Love it!
It even has a sleep timer on it. I'm in heaven.
Apr 27, 2010 | SanDisk Sansa Clip MP3 Player
Will the sansa e250 record books from CDs with chapters in ORDER?
The Sansa won't. You have to exercise a little care when you rip multi-disk audiobooks from CD to your hard drive. The scheme I use is to put a disk number at the beginning of the title (so I don't have to scroll to the end to see it). Then I just listen to the audiobook one disk at a time. I don't mind having to pause once an hour or so to go on to the next disk.
Apr 25, 2010 | SanDisk Sansa e250 MP3 Player
Getting the message: "Synchronize to listen to your audiobooks" How do I do this?
Make sure that you have Windows Media Player version 10 or higher installed. Then, run Windows Media Player, and connect your Clip to your PC. WMP should give you the ability to "sync" your Clip. Besides copying music to your Clip (if you want), this will cause licensing information on your PC to be updated and compared against the licensing information embedded in your audiobooks.
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
How do i fast forward through songs?
Press and hold the next song button.
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't transfer Audible files to my Sansa Clip
The link to the operating manual (which includes the Audiobook instructions) is here:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
What I would do is drag and drop the Audible files from the folder that Audible creates to store your audiobooks to the Audible folder of the Sansa Clip, instead of using the Audible Manager.
-Tha Mp3 Doctor
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
I use my sansa clip for audio books.
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Download book
To listen to audiobook content, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Music from the Main Menu.
3. Scroll down to Audiobooks and select it.
4. Use the thumbwheel to highlight and select the desired book.
5. Press the >>| button to skip to the next chapter or press-and-hold the >>|
button to fast forward.
5. Press the |<< button to go back to the previous chapter or press-and-hold the
|<< button to rewind.
6. Use the thumbwheel to adjust the volume level.
Oct 14, 2008 | SanDisk Sansa m240 MP3 Player
Sansa dioesn't recognize audiobooks
Maybe the new firmware will fix this.
"OGG placed in Audiobook or podcast folder shows up in Music directory." (see below)
(http://www.anythingbutipod.com/forum/showthread.php?t=30954)
01.01.30
Enhancements:
  • FLAC decoder support
  • Allow Podcasts to skip episodes using FF / REW
  • New startup and shutoff images
  • Improved the time to rebuild the metadata
  • Improved M3U playlist support
  • Enhancements for sorting Podcast contents which do not have their track number ID3 tag information
  • Separate missing license error message for Audible and generic Audiobooks. Message changed to instruct the customer in how to resolve the problem
Bugs Fixed:
  • OGG placed in Audiobook or podcast folder shows up in Music directory
  • Delete song from a long playlist causes the device to hang
  • Selecting “Back to Music List” while playing FM/Voice recordings will display double “Play All” on screen & will cause device to hang upon selecting “Play All”
  • Certain tag information for mp3 files will cause the device to hang or freeze
  • Made OGG file Tags not case sensitive
  • Noise problem on voice recording
  • Device in MTP mode will jump back to AutoSelect mode after UI format
  • Device behaves erratically when file extension got changed (i.e. .txt to .mp3, .jpg to .wma)
  • All Audiobooks should show 1/1 if Chapter Mode is OFF
  • Certain Rhapsody tracks show clicking noises
  • Deactivation message “Synchronize to listen to your Audiobooks” for Audible is uninformative and irrelevant
Oct 07, 2008 | SanDisk Sansa Clip MP3 Player
I can't pause a book
hi,
Have you tried reformatting it?
that might help as it could be a once off.
God Bless
Braydon
Mar 11, 2008 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
69 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
