Question about Pioneer DVR-112D DVD RW Dual Layer Burner
Autoplay will not work
I replaced the two DVD burners in two different machines with Pioneer DVR-112D drives. I have ultra data cables.
The drives work great except none of the four will autoplay. I tried everything incl. Microsoft autofix and Tweak.
I have had no bad burns but without the autoplay I cannot play videos.
The old drives all worked fine for autoplay but I wanted the faster and supposedly better drives.
I have Windows XP home with SP2 and Pent Celeron 3.46 and 3.2 ghz machines.
  • drynear Mar 01, 2008
    That naturally is the first thing I checked. From there I went to the Microsoft autofix and then Tweak.
    Nothing has worked.
    Genius:
  • 1,019 Answers
Try This:-
My Computer/Right Click On desired Drive/Properties/Options to autoplay required Types Et,c.
You should also have these Options, In Software Programs Such as Nero Or Roxio Et,c.
Mike @ Compurepair.
Posted on Mar 01, 2008
  • Mike Waldron Mar 01, 2008
    remember the advice i,m giving you on here is Free.
    I try to help people, resolve their problems.
    If you,d like a result for your Problem, within 1-2 Hours, i,d suggest that you pay the Premium rate @ $19.99.
    where a technical assistant will solve your problem.
    i give advice, at my own expense, and do not appreciate being patronised. Unless you actually state your competance.
    then you could be graded as ** useless-competant-semi skilled-professional et,c**
    when your given Free advice, be grateful for what your getting Free.
    Now my final suggestion to you, Is to remove 1 or 2 of the 4 Drives you have Connected, ensure that they,re jumpered correctly. Uninstall and re-install them.
    you could also check any settings in the system Bios.
    thankyou For using FIXYA.
    Mike @ compurepair.
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvr 112d power calibration error
updated firmware will not help. this is a known issue with Pioneer DVR-112D, drive needs to be replaced. Contact Pioneer for a free replacement, here is the url http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Notice+Regarding+CD+Read+and+Write+Functionality+in+Certain+Pioneer+Computer+Drive+Models
The issue occurs only under limited environmental and use conditions that are not typical for most end users, so Pioneer anticipates that most users will not be affected. If you are not experiencing any issues currently, there is no need to take immediate action. The service issue does not pose any health or safety risk.
Pioneer is aware of a potential issue with the above drives’ CD (not DVD) read/write capability. Under certain environmental and heavy use conditions, the above drives may become unable to read or write to CDs. To address this issue, for any of the above model drives that become unable to read and/or write to CDs, Pioneer will provide a replacement unit (which may be a newer model number) at no extra charge, shipping prepaid, subject to the terms and conditions of Pioneer’s standard limited warranty(excluding duration).
Again, we anticipate that most drives will not be affected. However, if your DVR-1810, DVR-2810, DVR-X122, DVR-112D, DVR-112DBK, or DVR-112DSV drive becomes unable to read or write to CDs, please contact Pioneer Customer Service by one of the following methods:
Complete an online replacement request form and submit it online. Once your model and serial number are validated, you will print out the completed form to mail along with the affected drive.
This online form is for United States customers only. For Canadian residents, please contact Pioneer Electronics of Canada customer service directly at 877-283-5901.
Mar 07, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr-
have you connected the 4 pin molex plug from the computer mainboard to the drive ?
is the IDE Cable correctly fitted ?
did you set the jumper connector on the rear of the drive to Master Or Slave ? if you are sharing the cable with a hard-drive, and the hard-drive jumper is set to slave, then the dvd will have to be set As Master ( otherwise they conflict ) or only 1 device will be recognised.
This should Solve your problem here.
Mike @ Compurepair.
Feb 19, 2008 | Pioneer DVR-112D Burner
PIONEER DVD-RW DVR-112D problem
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr 112d
look for the mark at the top, MA for master, SL - slave, CS - cable select, these three are main connection for IDE designation using the plastic jumper, just follow where it is in your pioneer.
Jan 13, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Installed new Pioneer DVR-112D
 Are you using an 80-conductor type ribbon cable? The new drive requires 80-conductor cable. Plus, you may need to switch the jumper on the back of the DVR drive to CS.
I just found your motherboard specs
http://h10025.www1.hp.com/ewfrf/wc/document?product=396434&lang=en&lc=en&cc=us&dlc=en&docname=c00063272
It uses SATA and Ultra DMA (80-conductor).
Is the jumper set to master?? You may need to pull the jumper off and see if the DVR drive works with it off.
Oct 29, 2007 | BenQ CRW 4012A (99.B9712.036) CD-RW Burner
Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Sep 13, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Check with a NEW PC - DVD Cable, if it is NOT that.. then I am sorry, but I reckon it's gone faulty somehow? Especially if it causes the PC to not boot. This is a common occurrence, even for NEW units..
Sep 02, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
82 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
