Question about RCA HD52W59 HDTV Projection Television
Rca tv the antenna/cable connector on the back of my t.v. broke so i took out the whole piece i dont know the part number or what is actually called. i am trying to figure out where i can but a new one at. any help???
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
It is called and RF connector. Unless you are very skilled at removing the tuner from the SSB (small signal bd) identifying trace paths and soldering I would reccomend a qualified service provider to replace this part. Another option would be to simply replace the tuner (the rf connector is pressed into the tuner). If you provide the service # from the back of set I can provide the part #'s.
Posted on Mar 01, 2008
Fixing the antenna cable input on a 2007 RCA
Disassembly will be required but you can replace the coaxial F connector on the rear.
Jun 25, 2016 | RCA Televison & Video
I have this tv and the antenna wire got stepped on and broke, is there a solution wth going in and replacing the connector. I was thinking and adaptor fron antenna cable to rca connector? is thiis...
well yes and know...let me explain.at theshop this is a very common occurence that we see alot... this connector is atached to a thing called a tuner. the tunner is what the tv use to select the channel. withhout this you cant change channels what can be done is atach a vcr and then use the rca inputs.. you will have to change channels using vcr.some cable boxs do this also again chaning through the cable box. this can be repaired depending how much damage has been done our shop ussaly charged around 85 dollars to repair the connector.
Dec 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
EWF TV ANT IN BOKEN
It can be soldered back on. With that particular model, I don't know if the connector is connected to the tuner or if there is a litte square anteena box which then feed a cable to the tuner.
Nov 26, 2008 | Televison & Video
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Cable/antenna connector
you can try to get just the coax replacement , otherwise you will have to get the whole tuner, and the number for the tuner is right on the tuner , but just soldering in a new coax connector is cheaper
good luck and thanks!
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
BROKE PART OFF TV-RCA F32665
Hi, some of those units have whats called a "RF cable" running from the back of the set to the tuner, and some are directly spot welded to the tuner, you need to remove the back from your set and see if yours is a short cable to the tuner, otherwise you have to replace the whole tuner, check the back of your set and you`ll see on a sticker the complete model number, (few numbers or letters after F32665) this is referred to as the service model number and I can look up exactly what you need to change
Nov 28, 2007 | RCA F32665 32" TV
That is an ITC222 chassis and one of the more dependable RCA units built. The "F" connector is the part you're referring to and it's not something that carries a specific part number for that unit. In the shop here we simply buy them by the box and the tuner will have to be removed to install a new connector. The new one will be soldered to the chassis of the tuner and less likely to break in the future. Not something you probably want to do yourself, but at least you'll know what to ask the shop when you're calling around for estimates.
Nov 05, 2007 | RCA D52W19 52" Rear Projection Television
Snapped cable input
It all depends on what actually broke. Those input connectors are usually 90 degree metal units, soldered to the circuit board, so possibly the connector took a chunk of board with it. Any competent TV technician should be able to repair this in your home, especially if you tell them what the problem is when you call them. That way they will know what parts to bring.
May 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
