Picture freezes the picture freezes after 20 munits of operation. I shut it off for a minut and it will run again for 20 minuts
  • Eddie Comeau
    Eddie Comeau Mar 01, 2008
    it is a samsung HL-S4265W
    Novelist:
    Scholar:
  • 96 Answers
What horror, it must be an RCA, no no a LG, no no maybe a cheap Walmart brand inported from China, ya that got to it,
Not enough info, can't answer.
What About bob
Posted on Mar 01, 2008
  • robert landry Mar 01, 2008
    Hi. Wish I can help you but never worked on this model, the problem your or explaining sound like a cpu problem or a power supply problem.
    Have you tried tapping it gently on the side to see if stop's. If it does then it would be a solder connection problem.
    Can't tell you more wish I could
    Thanks
    What About Bob
Low ice output
Low ice production has multiple causes. First check condensing coil to see if they are dirty and not passing air. This is the most probable cause for low ice production. Next, measure freeze cycle time and harvest time. Freeze time is typically 20 to 30 minutes and harvest time is normally 1.5 to 3 minutes. If freeze time is long (> 35 minutes), first check water valve shuts after reservoir is full. If it does not shut off the water solenoid operated valve needs replaced. Second, find the harvest solenoid operated valve which branches off the compressor discharge and port high temperature gas into evaporator during harvest and see that evaporator side of harvest valve cools down to surrounding temperature in a few minutes 8 - 10 after freeze cycle starts and harvest time stops. If it does not cool off the valve is leaking by its seat and will require a technician to replace. Lastly, if long freeze cycle could be due to low refrigerant and will require and tech to charge properly. Ice machine are critically charged and a tech will know how to charge the right amount. Again, it is possible the metering device is not passing enough refrigerant and a technician can determine this by checking the superheat and subcool. Low subcooling <3 and a high superheat >20 typically indicate an txv (metering devise) needs replaced and will require a tech to replace.
Oct 13, 2013 | Scotsman Ice Machine - 290lb...
Volvo 960 AC problem
TX valve freezing?
Jun 22, 2012 | 1997 Volvo 960
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
I have a 2000 s500 engine just shut off by itself
you need to have car scanned for codes and it sounds like it is due for a major service
Aug 30, 2009 | 2000 Mercedes-Benz S-Class
LG 1200 btu ac unit works fine for 20 minutes then shuts off compressor and continues to run fan only. Shutting it off for 15 minutes and then works fine again for 20 minutes.
You do not say if it is outdoor or indoor fan which operates. However I presume all your filters are clean and the drainpipes are clear. The only other thing you could suspect is the thermostat or air flow sensor.
Jun 25, 2009 | LG Heating & Cooling
Dryer runs for 20 minutes. shuts down. won't start again for 2 hours.
Hi, It sounds like you have a motor going bad. If this is a whirlpool brand models, the motor is about $90.00 to $100.00. If I can assist you further, please let me know.
Thanks
Vic
May 21, 2009 | Dryers
Engine stops running after warming up.
you have a failing crankshaft position sensor
Apr 13, 2009 | 1990 Oldsmobile Cutlass Supreme Conv
TV shuts off on it's on after about 20 - 30 minutes of play
freeze like the picture is in pause?
picture freezing is desired function on the remote and handled mainly by the "picture and picture" circuits. but the video that is involved and processed there is handled by many circuits and microprocessors.
what you describe is an intermittent heat related problem if you almost can set a watch to the the shut-off time. you can feel, if your a tech, what part is running hot with a finger or start freezing a suspect part with freeze spray and see if stays on long past overdue. make sure your vent holes in the back are not covered and keep the back at least 1/2 foot from the wall.
May 19, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
