Question about Hotpoint WMA31 Front Load Washer
Machine programs ho i have a hotpoint machine i think its wma31 i dont have an intrustion book will you be able to tell me what each program dose thx
  • 121 Answers
Why dont my Nuova simonelli Musica pour when pressing the Continuous coffee dispensing button? The button flashes.
have you tried programming the doses, maybe your continuous dose is not programmed. if you did, botton switch damaged need to replace whole touch board
Jun 22, 2014 | Nuova Simonelli Musica Espresso Machine
I have a hotpoint WMA31 washing machine. It has developed a fault. It stopped halfway through a wash cycle. I turned it off, drained it by switching to a short spin so the pump is working just fine. It...
hello graham the fault could be down to the module board the controls the motor speed. not sure where it's ;ocated on your model but the board usually sits at the back of the washer may wires coming off it hope it helps
regards
shaun
Oct 12, 2011 | Hotpoint WMA31 Front Load Washer
My hotpoint wma31 won't start, the program lights up when selected but the wash won't start. any ideas what could be the problem, it's a great machine otherwise and its never happened before....
It's a good machine. Well done for keeping it that long. It sounds like maybe it thinks the door is still open. (What happens if you intentionally try to start the program with the door open - It the result exactly the same? If it is, then it's probably the door interlock sensor.
If this is the case then you may find that a couple of good slams of the door will free off anything taht is sticking. Otherwise, you may have to check to see if there is a wire off the sensor (They do fall off sometimes) or.. after 13 years, it may need a new door sensor
Jun 28, 2011 | Hotpoint WMA31 Front Load Washer
My Hotpoint WMA31 will not drain - the smell is
check for blockage under cap bottom of washing machine
May 26, 2010 | Hotpoint WMA31 Front Load Washer
Can let me know how to go about changing the
hi joe i do these machines on a reg time almost every day.it easy to do the way you are doing it is the wrong way .so heres how to do just take top of the machine and put the belt on the small pully on the motor then half way round the drum wheel and turn it till its on make sure the belt is in middle of the pully if its not it will slip off i belive this is a hotpoint wma31 if belt keeeps comming off your bearings have gone it will need new bearing s good luck any more help just email me at marrathedolphin@hotmail.com
Mar 26, 2010 | Hotpoint WMA31 Front Load Washer
Fills water goes through program drum dose not
Remove the motor, and check the brushes in the motor, if o/k, then could be a board prob, or something as simple as a broken or bad connection.
Pleasre rate my solution.
Thanks.
Oct 10, 2009 | Hotpoint WMA46 Front Load Washer
HOTPOINT washerdryer WD420 The door dose not open after wash and there r no flashing light.Can any1 help plz with thx.
The interlock is stuck, you need to get behind the casing to release. this can be done by taking the top off and reaching down to the door mecanism and pushing the lever open. CAUTION disconnect the machine from the electricity supply before attempting this.
Nov 04, 2008 | Hotpoint Aquarius WD63 Front Load...
Filter
take off rear bottom panel.
you will see a large diameter pipe going from bottom of machine to pump. take off this pipe at the machine end - careful, lots of water may come out.
filter is located inside this pipe. remove and clean
Aug 31, 2008 | Hotpoint WMA31 Front Load Washer
Dont understand what the programs do
my hotpoint aquarius wf540 lights keep flashing
Mar 01, 2008 | Hotpoint WMA31 Front Load Washer
Hotpoint WMA31 Front Load Washer Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
