Question about Husqvarna Viking 1
Zero turn Husqvarna Mower
I changed the hydraculic filter and oil. Now the mower will not go forward or reverse. The pump pulleys are turning. Before doing this everything was working. Could I have air in the lines? If so, how do I bleed the lines?
    Novelist:
  • 87 Answers
Wrong area, the Viking #1 is a sewing machine not a mower.
Posted on Apr 28, 2008
I have a Husqvarna Viking Quilt Designer II that the reverse button does not reverse. It continues to sew forward when I hold and press the reverse button. Thank you for your help.
If, the machine has been sitting, take a hair dryer and heat where the reverse lever is. Try this, it worked on mine. If, that does not work, try cleaning and oiling your machine according to your manual.
Nov 19, 2017 | Husqvarna Sewing Machines
My euro-pro 7130 seems to be stuck in reverse. I cannot make it sew forward
This can be caused by a few things. Check the stitch setting near zero can cause this. Next check to make sure it is on straight stitch. If that doesn't work the reverse mechanism may need oiled. If this is a computerized machine you may need a repair shop to do it. You do not want oil on the electronic boards.
Oct 24, 2013 | Euro-Pro Sewing Machines
I pulled the releases to push the mower out of the way, now it won't do nothing
if this is a lawn mower, you should put the question in the mower
catagory,,and someone will be happy to help you,, it was put in the
sewing machine catagory by mistake.
Oct 11, 2012 | Husqvarna Viking 1
Husqvarna lt130 engine seized
Think this is posted in the wrong section, I,m guessing yours is a grass mower not a sewing machine
Apr 25, 2012 | Sewing Machines
Hi dear expert I have a Husqvarna SM 125 '07 (zCGH200AB7V011268) I have such a problem: blinking light oil (3 long 3 short) oil in the tank is full, look forward to your reply, Regards Nazar...
That warning is for the oil pressure- it's missing. Check the pipe connecting the tank to the oil pump and the cartridge filter. If they are free then the pump and the engine will have to be dismantled to identify what went wrong.
Sep 22, 2011 | Husqvarna Designer I
I'm loking for the rear wheel for a push mower model number 917.374426
Lowes and/or Home Depot carry replacement wheels in a few generic sizes, or your local mower-repair shop can order it for a bit more.
Apr 05, 2010 | Husqvarna Designer I
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Sewing backwards
The reverse button works by hitting it twice in succession to make it stay on (it lights up), and you turn it off my hitting it once again. If you just want to reverse for a little bit, you hold it down while you sew, then let go. Is the button lit all the time?
Having said that, it sounds like Nannayoyo needs to take her machine to a service centre - the electronics behind the button panel might need replacing. Is it possible the button is stuck in? Maybe phone a Husqvarna service person - not a sales person - and ask for advice.
Everyone - are your machines new? If yes, you need to go back to the sales centre straight away and get it fixed or replaced while you wait. If these are problems that have just appeared when your machine used to work perfectly, probably the best solution is to take it for a service. It might just be a speck of dust has settled on the electronics behind the panel and is causing unpredictable behaviour.
Dec 09, 2007 | Husqvarna Designer I
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
143 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
