Sony Ericsson K550i Cellular Phone Logo
Posted on Feb 23, 2010
No network coverage - Sony Ericsson K550i Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2767
Points
12
Network IC Problem. We also faced the same problem here. The Signal Bar shows Full Strength for a few Seconds and immediately drops down to Zero Strength but it Displays the Operator Name.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
573
Points
Network coverage is breakdown
sanka ruwan chamara
Level 1:
New Friend:
  • Posted on Oct 14, 2014
sanka ruwan chamara
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
573
Points
No net work caverage.same time have signal.what is the poblem.plz help me
Nokia N72 No network coverage
To set Nokia N72 No network coverage problem, go to the network selection ,there select automatic network or try manual search for the network and see if that helps.
1helpful
No network coverage solution
try to update using www.updater service.sony ericsson
3helpful
2answers
I ve a nokia 2730 classic model ...m using airtel service... when i set umts mode there is no network coverage
This probable if your Network does not have 3G/UMTS coverage in that specific area.
I would set your phone so that it will automatically select 2G or 3G network services (e.g. often referred to as Dual-mode) so that if 3G/UMTS is available and has the best coverage/signal, it will automatically be selected. Setting UMTS coverage only would be very restrictive in many area as the signal is usually weaker (especially in Buildings).
Hope it helps!
8helpful
5answers
No network coverage sony ericsson k800i
how can get net work coverage in k800i sony ericsison mobeile phone
2answers
your phone must be an imported one if not contact your mobile vendor and have an unlock
Network searching problem.
change the antenna of your unit, if it doesn't help, your unit needs reformatting or reprogram.
No network coverage/signal problem
i had no display on my nokia 3230 cellular phone. now its ok but it has no network coverage/no signal . plz help me..... .
1helpful
2answers
NO NETWORK COVERAGE ON MY SONY ERICSSON K800I
Try setting your handset to manual network selection and select the network for your connction provider. If you don't roam around much, this works well. Please revert back to the automatic network selection if you go on Roaming.
Try & reply.
6helpful
2answers
No Network Coverage!
what do i do if my nokia doesn't have any bars and if i try to call it says call failed or network not availible
Network problem
Try manually selecting your network. Where are you located?
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
