Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Whirlpool DU1055xtss doesn't fit cavity where old Whirlpool dishwasher exists
I bought the above dishwasher but the tech couldn't get it installed in the existing space because existing unit is 33-1/2" and new unit is 33-3/4". Is this really an insuperable problem? There was some talk of a "tall tub," are there short tubs? He suggested a Maytag. Is he yanking my lanyard?
I got my money refunded but still need a dishwasher without raisin the counter or lowering the floor. Tks in advance.
  • carlos Mar 02, 2008
    Yes, that's good advice. As soon as my blood pressure came down I realized a second opinion was the right thing to do. Thanks
  • Lou123456 Mar 03, 2008
    Would like to install a new tile floor, but the idiots who installed the very expensive countertop used 1/2 plywood when I had 3/4 plus old plus 1/2 backerboard. Ripped up old vinal floor and 1/4 pressboard. Now I have 1/2 inch for my floor and need 3/4 plus play to move it in and out. I'm screwed. Yes, my blood pressure is very high today. I can't find a replacement dishwasher. my new applicances -minus the dishwasher are bisque.
    President:
  • Whirlpool Master
  • 2,651 Answers
Best bet go see your local KNOWLABLE sales rep. generally the mom and pop better then the big chains for knowing what will and wont fit your height requirements
Posted on Mar 01, 2008
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
Whirlpool DU1055XTSS dishwasher is totally dead as if it were unplugged. No response from front lights. Only 3 years old. Another post for an different Whirlpool model says it's the thermal fuse, but I...
If you have power going to the dishwasher, meaning the breaker, switches, wiring and fuses in the home are okay, the most common cause for your symptoms is the thermal fuse.
The thermal fuse is a small disk shaped device that is behind the control panel on the right side it is snapped on to the electronic module. The part number for your model is W10258275
Jul 24, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Hooking up a drain line
Connect directly to your existing drain lines under the sink or to your disposal unit.
If you do not have a dishwasher drain adapter on your drain lines the local home center will help you. Install above your S trap. Cut just enough of the pipe out to allow for the new part to slip in (half and inch or so goes into the fitting). You will need glue and primer.
If you connect to your disposal there is a fitting on the side of the disposal to accept the drain line. You should have a fitting supplied with the disposal. If not the local part supplier can help you. Break out the tap on the disposal and connect the fitting and drain line.
Hope this helps. Please rate the answer if it helps you.
Mar 10, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashwer wont fit under counter
it depends on how much tallerit is . you can adjust the legs but you have to know how much. if this helps let me know.
Dec 27, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Replace dishwasher / counter tops are not standard
i have had that problem before and used a saws-al and cut the legs and what ever else i needed to get that puppy out.the question is will your new one fit?in my case most all i ever tried to install i got them in.and i have done a hundred or so
Feb 03, 2009 | Whirlpool Dishwashers
Whirlpool DU1055XTSS trouble shooting
i wouldn't worry too much about shortening line, unless its extreme. ck fro possible restriction in line(possible kink ) or the sink down spout that is draining into. a d/w will ***** remove all the water after cycle is complete, its normal to have a small amount of water just below or above the filter plate
Mar 10, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
855 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
