1991 Dodge Shadow Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 91 Dodge Shadow locked up on me while my friend and I was trying to get it unstuck from backing up onto a snow pile. I put it in neutral and we pushed it off the snow pile. When I got back in my car to try and start it, I couldn't turn the key nor the wheel. Now my car is sitting in the middle of the road with no way of moving it and other cars can barely get through. Please help me out. How do I get my key to turn and wheel unlocked?
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
12798
Points
64
You're going to have to jostle that wheel pretty roughly from my experience...
If it's an Automatic Make sure you are truly in park or neutral before removing the key.
If it's a manual you might have to rack the release button harder then usual. My 90 can get finicky in the cold sometimes.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 236 Answers
  • Posted on Feb 23, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
236
Questions
6
Helped
75786
Points
744
Move the steering wheel left and right and try to unlock it like that. it might be hard but i think that shouild help
91" dodge shadow
What is a 91 inch shadow?
Does my 91 Dodge Shadow have a speedometer sensor and where is it located
The speed senser on my 91 2.2 is under the car almost directly behind the oil drain plug on the upper side of the axle housing it has an electrical plug no cable it's held on with 1 bolt remove that and it pulls up pretty easy to expose nylon drive gear.hope that helps
I have a 91 dodge shadow a 2.2 i have no idea where the low side of the A/c is . I need help or a diagram
Usually the larger diameter hose and tube/line. Follow line until you see the fitting.
I have a 91 dodge shadow and it feels like im losing power when trying to speed up sometimes even feels like im running out of gas. Any idea what could be wrong? Also I bought a new convertible top and...
check your cat. converter it might be clogged my cavaleir was acting like that and it was the cat was bad had it replaced with straight pipe ran great hope this helps
Where can I find bushing kit for 91 shadow alternator mount #4556173
i would advise you make your own as this is an obsolete vehicle by now as its 20 yrs old and most manufacturers only keep spares for vehicles up to 10 yrs ,could you not try a scrap yard for a piece they would no doubt give you the spacer bush if you bought some other things
1helpful
My wife got stuck in snow with her 2002 alero and couldn't get unstuck. I pulled it out with my truck with her vehicle in neutral. now it leaks transmission fluid. It must have been from when she was...
It probably had been leaking or something damaged the pan. You will need to look for the leak location. pulling a car out will NOT cause a leak.
I had to run a wire from my starter because it stop starting with the key for some reason plus my back up lights are not working. It's a 91 dodge shadow
Well ya know it ain't the starter or the battery!
Now you have to check out the starter relay, ignition switch and neutral safety switch.
Back up switch must be defective or open in circuit.
It could also be the bulbs
Best thing to do is to get the shop manual and check out the items I listed. I could tell you how but the explainations are lenghty and its easier when a booh is in front of you. There is no brain surgery involved here a digital voltmeter and the shop manual should do the trick
13helpful
2answers
SUZUKI ESCUDO N 4H 4H LOCK 4 L LOCK
I will assume you have the same thing as in a Suzuki Grand Vitara :
N : Neutral : use this when you tow your vehicle.
4H : Use it in normal road conditions, highway, etc.
4H Lock : Use it on offroad, snow, sand, ... etc
4L Lock : Use when you are stuck on snow or sand, BE CAREFUL, this mode is only for difficult situations, do not exceed 25 MPH, and do not use it in normal conditions.
Hope this help.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
