Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook NO sound
Hi there, pls help!
theres no sound coming out of my macbook when i try to play my itunes. I only hear the sounds if i use my earphones and when i take it out, no sound anymore. pls pls help!
  • CAROLINA Jan 21, 2009
    I try to plugged the headphones, but it work only with the headphones plugged. Im in SYSTEM PREFERENCES, HARDWARE, SOUND, OUTPUT and with the HEADPHONES PLUGGED work... but then, with my headphones UNPLUGGED, THERE IS ANYNOTHING!!!     : (
    Could somebody help to me???
    Thank you.
  • 667 Answers
Sound settings are controlled in the System Preferences, have you checked there?
Posted on Mar 01, 2008
Cannot hear sound from iTunes on new computer with windows 8.1
At this point I am not sure if you can be able to here sound from any of your installed players like Windows media player or VLC or anything like that. Well if you can not here any sound coming from the computer from any of your players, then there must be a problem with the sound or audio drivers on your computer. They might have been deleted or altered in some way. You just need to go to the website for the manufacturer of your computer and download the audio drivers that are compatible with windows 8. But if you can hear sound from other players except Itunes, then I suggest that you uninstall and re-install Itunes on your computer. The case might be that the Itunes was installed with a few errors and this might cause problems like what you are experiencing now. Re installation might work
Oct 14, 2014 | Microsoft Windows 8.1 - Windows
No sound on my macbook
Check if there is any sound coming out of the headphone (using headphone and playing itunes).
If there is none. Goto System Preference > Hardware > Sound > Output ; check if the output is assign to internal speaker and it is not muted.
Do a visual check at the headphone connector, look into it, see if you see a red light emit from the headphone jack (indicate that the fault is in the headphone connector, it's trying to output optical spdif).
Nov 28, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Im using a macbook, im not able to hear any thing in a voice conference in yahoo messenger.. pls help
check your preferences in the apps. Do you have headset plugged in??
there are sound options in yahoo messenger preferences, check those first, as well as your system preferences sound settings.
sometimes, its just plugged into the wrong input, and/or not set to hear/talk with a headset.
May 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sounds like my computer underwater
Try to update the Itunes and Mac OS X.this can solv the issue
Mar 09, 2010 | Apple MacBook Pro Notebook
Macbook booting with startup noise but no screen activity!
there is no backlight or vga fault posible to fix Micromend London goop poeple
Aug 30, 2009 | Apple MacBook Pro PC Notebook
The disc drive on my macbook keeps ejecting CDs/DVDsa couple seconds after inserting disc into laptop
it sounds like it is not reading the discs
it could be a faulty optical drive...do u hear weird sounds when its trying to read it?
Aug 10, 2009 | Computers & Internet
No sound from iTunes audio files
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Jun 23, 2009 | Audio Players & Recorders
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Macbook Pro Right speaker isn't working
I hate to break it to you, but it sounds like a hardware issue. Have you tried going into System Preferences yet? If not, go to System Prefs>Sound>Output tab and then check the speaker balance. If the slider is in the middle, then it definitely sounds like a hardware issue.
I'm going to guess you've had your MBP for a while now, which would mean that something inside like a speaker wire could have gotten knocked around enough to just fall off, or loosen a connecter just enough to make the speaker not work. That is, of course, if it is not System Prefs. Let me know how it goes.
Aug 25, 2008 | Apple MacBook Pro Laptop Computer with...
No picture
hi!
you can download the power dvd player.
because other computer you can play and hear the sound but no picture.
PS:
pls rate if is invaluable solution rate me fixya.
thx
May 22, 2008 | Toshiba SD-P1400 Portable DVD Player
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
161 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
