Question about Xerox Phaser 8500/DN Printer
Phaser 8500 color printing issue - pdf file
Our small office has our Phaser 8500 networked to two computers. When my boss prints out our media kit (pdf file) which has all green headers , one header prints in yellow. They are suppose to be all green.
When I print the same document from my computer, all the headers print yellow except only one header is green. It ends up being the opposite of my boss' copy. We can't get either document to print all green.
The print quality test comes out great. I don't know why we can't get either computer to print the pdf with all green headers.
HELP!!!!!!!!!!!!!!!!! :)
thanks Barb
  • BarbSF Mar 04, 2008
    hello,
    thanks so much for the tip. No one in this office is tech savvy and I was able to follow your "direct pdf instructions" quite easily. Of course, when the printer was networked it wasn't set up with this feature. Printer read out "this printer is not configured to support PDF printing".
    So I've now made this my small project to work on that part so I can try your suggestion.
    thanks again! Barb
    President:
  • 2,072 Answers
Try setting up PDF direct printing..
> Support & Drivers > Phaser 8500/8550 Support > Search Results Solution: Perform PDF Direct Printing From Microsoft Windows 2000 / XP / Server 2003 OS and Apple Macintosh OS X (10.x) Phaser 8500 color printing issue - pdf file - bttn_print.gifMake Printable bttn_email.gifEmail thiPhaser 8500 color printing issue - pdf file - elem_1_spacer.gif elem_1_spacer.gif PDF direct printing can be used to send a PDF file to the printer without having to open and view the file on a computer.
NOTE: PDF Direct Printing may not be successful if the printer does not contain a hard drive.
Depending on the OS being used, click on one of the following links:
Macintosh OS X
To download a PDF file directly to the printer from Windows 2000 / XP / Server 2003:
To download a file to a printer that is connected using an Ethernet (network) cable, use the FTP command or CentreWare Internet Services (CWIS). To download a file to the printer that is connected directly to the computer with a USB cable, use the Xerox File Downloader Utility.
To download a file to the printer using the FTP command:
NOTE: To perform this solution, the printer must be connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
Not all web browsers can be used to perform this solution. If problems occur when performing this solution, download the file using CWIS. See the To download a file to the printer using CWIS section below.
  1. From the computer, open an Internet browser window.
  2. Type: ftp://xxx.xxx.xxx.xxx, where the x characters represent the IP address of the printer, in the Address field.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below for additional information.
  3. Press [Enter] on the keyboard. A blank FTP connection window with a [.] icon will be displayed.
  4. Drag and drop the file to be sent to the printer into the blank FTP connection window. The file will be sent to the printer.
To download a file to the printer using CWIS:
  1. From a computer, open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
    NOTE: The IP address of the printer can be found on the Configuration Page. See the Related Items below.
  3. Click on the [Print] button.
  4. Click on the [File Download] link in the list of options on the left side of the window.
  5. Depending on the browser being used, click on the [Browse] or [Choose File] button, and then browse to and select the file to be downloaded to the printer.
  6. Click on the blue, square button to send the file to the printer.
To download a file to the printer using the Xerox File Downloader Utility:
NOTE: This solution assumes the Xerox File Downloader Utility has already been installed on the computer. If necessary, click on the [Drivers and Downloads] link under the Product Resources menu on this window to download and install the utility.
  1. From the computer, open the Xerox File Downloader Utility. By default, the utility is installed in the following location on the computer's hard drive: C:\File Downloader.
  2. Select the required printer from the Select the printer to spool the file to from the list below pull-down menu.
  3. Click on the [Browse] button, and then browse to and select the file to be downloaded to the printer from the Select the file to sent to the printer section.
  4. Click on the [Send] button to send the file to the printer.
To download a PDF file directly to the printer from Macintosh OS X:
Files can be downloaded to the printer using the Print Center or Printer Setup Utility, or by using CentreWare Internet Services (CWIS).
To download a file to the printer using the Print Center or Printer Setup Utility:
NOTE: This method can be used for Ethernet (network) and USB connections.
  1. Open the Print Center (for Mac OS 10.1 - 10.2.x), or the Printer Setup Utility (for Mac OS 10.3.x and 10.4.x):
    1. Double-click on the [Hard Drive].
    2. Double-click on the [Applications] folder.
    3. Double-click on the [Utilities] folder.
    4. Double-click on the [Print Center] or [Printer Setup Utility].
  2. Double-click on the printer that needs the file sent to it. The print queue window will be displayed.
  3. Drag and drop the file to be sent to the printer in the print queue window below the Name column. The file will be sent to the printer.
To download a file to the printer using CentreWare Internet Services (CWIS):
NOTE: CWIS can only be accessed if the printer is connected to a network that utilizes the TCP/IP protocol. The printer must also contain a valid IP address. If necessary, contact your System Administrator for additional information.
  2. Enter the printer's IP address in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services home page will be displayed.
  6. Click on the blPhaser 8500 color printing issue - pdf file - elem_1_spacer.gif to send the file to the printer.
Posted on Mar 01, 2008
Can i print B&W copies on the color zerox 8500 phaser?
Most likely the IP address has reset. If you have your configuration go into network setup, then re enter your IP address, and turn DCHP off, make the IP address static,
Feb 16, 2010 | Xerox Phaser 8500/DN Printer
Fault 37,016.43:9533
You've got some physical problem inside the printer.
See:
http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enca.html
If your printer is networked, it can actually communicate with our support knowledge base directly, and troubleshoot itself.
Sep 10, 2009 | Xerox Phaser 8500/DN Printer
When printing .pdf's to HP 8500N ..I get a stackdump sse more inf
I find most PDF printing issues are due to the print Driver. Your print driver should be a Post Script driver they offer the best support for PDF files.
The issue your having is most likely due to the print driver. First step would be to replace your driver.
Print the document again.
If it does the same thing, then it could be caused by the actual PDF file your printing.
Print other PDF documents does it do this with all PDF's?
If so your Acrobat Software has an issue. Reinstall Acrobat.
Print PDF's again.
If the problem remains then it becomes a issue most likely caused by your Operating Sys of your computer.
Jul 27, 2009 | HP LaserJet 8500 Color Printer
PDF documents do not print completely on my Xerox Phaser 8500
I am having the same problem. Sometimes my Xerox Phaser 8500 prints a PDF or web page fine, and other times I get pages and pages of what looks like PostScript code. I thought I had installed the most recent printer drivers, We are using primarily Macs with OS 10.4 or 10.5. One recent change is that we connected the printer to an Airport Express using a USB cable, which is sweet when it works correctly....any ideas???
Jul 14, 2009 | Xerox Phaser 8500/DN Printer
Xerox 8500 not printing
It sounds like you need to check your addressing. Sounds to me like your IP address reset back to default.
You need to go into the network settings and check your IP address and make sure it is set to manual and not auto.
I believe your printer did a reset and your address is wrong.
Jun 27, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 color issue
In all honesty, I suspect the print head has some bad jets on it.
Xerox will not warrany it since there is the presence of non xerox ink in the print head.
When you have tried as much as you have with the maintenance cycles. I would suspect a bad printhead.
When the jets become blocked to the point where you cant get all the colors sprayed onto the drum, you get mismatched colors.
Apr 07, 2008 | Xerox Phaser 8500/DN Printer
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser  8500/DN Printer Logo
1,096 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
