Holden barina xc and the passenger side blinkers front and rear are not working, I tested the bulbs and they are OK - the fuse that operates the hazard lights and blinkers (fuse no3 - 7.5a) is OK any ideas?
Holden barina tk 2007 engine won't start. ? run the fault codes check that the cam shaft is turning ( broken timing belt) check immobiliser for correct operation ...
Holden Barina P1700 OBD-II Diagnostic Powertrain (P) Trouble Code Information Page. Reason for Holden Barina P1700 and find the solution for the code ...
There should two separate bulbs for marker and blinker. It sounds like a bulb is burnt out, bad ground, melted socket or a wiring anomaly. Are you certain it's supposed to have 57 series dual element bulbs for blinker and markers?
Hi Brian did they just suddenly stop working?
start with the basics check fuses, fuse position and description should be labeled on inner fuse box cover. Check globes are ok, Then check indicator switch ( I suspect this may be where fault is). Give switch a bit of a work out, switch it up and down several times, wiggle it around and see if it comes good possible dust on contacts. If fault is still apparent get a Dealer or auto electrician to have a look as it now becomes more involved. Test equipment will need to be used. Good luck.
side of motor firewall side down near cv shaft that goes into gearbox if you look there you will see a 8mm bolt with the sensor going into the side of motor
Locked stereo in 1995 Holden Barina My battery went flat in my barina and now the ... Just changed the battery in a 2001 Holden Barina now there is no power just ... fuses should be in the box under the hood, there will be a diagram showing ... a 1984 gmc jimmy s15 fuse box located? the fuse box should be located near or ...
Apr 19, 2013 - 2002 Holden Barina from Australia and New Zealand - Comments ... The relay is in a box with a plastic cover on the left side (passenger) beside ... Hi, your Combo problem is the MAF sensor located near the air intake ... Hi I was hoping youfound the problem to your car, as my daughter's 2001 XC Barina is ...
check that when you turn on the heater control that it is actually turning on the hot water tap. They are mostly vacuum operated and the little hoses break or rot or become pinched.
Usually a fast turn signal means that there is a light out. You should probably check all of your lights, including back-up lights, and turn signals. If there is one out then replacing the burnt out bulb should fix the problem.
