Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca hdtv big screen
Channel is stuck on 14 after screen was hit? How do i fix it?
    Scholar:
  • 133 Answers
Your front panel buttons may be pushed in not allowing it to change channels. The only way to access this is to remove the speaker grille . Most are screwed in on the back side . Once this off you should see the panel with your buttons on it . They use clips to hold it in place. Be careful as they can break easily. Once the panel is off inspect the buttons and the board it might be cracked . Make sure tv is unpluged when doing this . Good luck
Posted on Feb 29, 2008
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
My rca big screen hdtv's screen is messed up
it is the convergence.normally can be fixed by replacing a fuse
May 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Stuck on Demo mode?
try to hit back the tv by your hand then try to resolder back the tv ic board maybe some electronic part is loose contact
Mar 24, 2009 | Panasonic CT-36G24 36" TV
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
My RCA is a big screen 52 " is about 7 years old
yes this problem can be fixed but the price may scare you!
Sep 09, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA big screen has gone crazy!
Sounds to me like you may have a cold solder joint in a board ( loose lead on the pc board ) or you might have a b ad eeprom causing the problem. You may need to replace the main board. Also another sitution I have come across is a stuck button on the tuning strip board ( the board/switches that change channels, volume etc ) on the tv. maybe also since the remote sensor is light senative, it may be in the line of the sun ( cover the ir senor on the front of the tv to illaminate that problem ). Good Luck and if you the suggestions don't correct the problem. email me at wyoed1@aol.com or continue with this at this address. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | RCA P52939 52" Rear Projection Television
RCA HDTV Tru Flat 27"
I had that problem, it was the tuner.
Nov 11, 2007 | RCA TruFlat 27F520T 27" TV
RCA HDTV 52# is zoomed in
Had the same problem....If you have a digital cable1.gif box through Comcast1.gif there is a setting on the box that will fix this problem.
Nov 02, 2007 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
