Question about Dell E176FP 17" LCD Monitor
Different color test patterns keep cycling .
As soon as display is powered up, some sort of test patterns keep cycling and the buttons do not seem to have any effect except the power button. After about ten minutes, the pattern stops cycling and remains locked on a triple blue gradient pattern. At this point, even the power switch has no effect. The colors are radient so I don't believe it is a power supply problem. This occurs regardless of disconnecting from the computer.
  • arthur1 Mar 01, 2008
    Dave, thanks for trying, but I actually tried that first. Dell says that with nothing hooked up, their logo should be displayed, and then a " No Video" message should show up. This unit goes into the test patterns even with good video applied.
  • 4 Answers
This could be a computer or monitor problem. The reason that display shows up is because the monitor is not getting a power good signal from the computer. If a monitor doesn't get a power good signal it goes into test mode. It could be the monitor has a fault that is not allowing it to detect the computer, or the video card or computer itself isn't functioning properly. If you can, hook the monitor to a computer that you know is working properly. This will tell for sure if it is the monitor or not, and eliminate that possiblity. Then you will know if it is the monitor or computer. If the computer is the problem you'll need more help troubleshooting it.
Dave
Posted on Feb 29, 2008
  • Dave Reed Mar 01, 2008
    Yeah, I'd say it's definetly the monitor. There are some companys that do repairs on LCD's, but it's usually just as expensive than buying a new monitor, sometimes more expensive.
    Dave
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
Cannot make the printer work after I changed the ink cartridges?
You can validate the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test: http://inkjet411.com/?page_id=440
1. While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
2. Release the Power button.
3. The 'Tap 41' diagnostic test print should print.
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout. http://inkjet411.com/?page_id=434
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Sep 01, 2013 | HP Deskjet F2480 USB 2.0 All-in-One Color...
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
It doesn't show red color. i tried to do factory reset. but still problem.
1.After turning on the projector, press "+" and "-" buttons on the control panel
3 While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Contact Dell if the colors are not displayed correctly.
Mar 01, 2011 | Dell 2400MP DLP Projector
Vizio plasma Tv Model P42Hd ,Tv has gone into some sort of test pattern on screen, has a color band of several colors from left to right on screen. The colors move up and take the position of the one...
with set unplugged, hold down channel up and down on the front panel at the same time while you plug the set in. Power light will go amber like it is in the off mode and when you hit the power button the set should come up and be normal.
Dec 17, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My printer is copying but printing out blank sheets- i tried changing out the ink but still not working?
I'm assuming you mean all pages come out blank, whether using the copy or print function. Sounds like the printhead is seriously clogged, but we may be able to blast it out, working from the machine's operating panel.
If you've already run it through a few normal cleaning cycles, skip down to the paragraph marked Purging.
For a normal cleaning cycle, touch the Ink button, near the left end of the operation panel. Use the up or down arrows to select "Cleaning" sand press the Menu/Set button. It will give you the choice of cleaning Black, Color, or All. Use the up/down arrows to pick All, then press Menu/Set. Sit back and wait a while.
When it's done, use the same Ink button and select Test Print, then Print Quality. Press the Color Start button to print a pattern of four blocks of dots, one block of each ink color. If you're getting ink out, but not perfect blocks without gaps, you may want to repeat the cleaning & test process.
If it's totally blank or a hopelessly small improvement, try purging the ink lines and head:
Purging: Brother has built utilities into the machine to allow servicers to aggressively purge the ink lines,at the expense of considerably more ink consumption than a standard cleaning cycle. First we need to get it into the "Maintenance Mode":
Ignoring any beeps meant to distract you from accidentally doing this, touch Menu, Black Start, then the up-arrow button four times , that is: Menu, Black Start, ^, ^, ^, ^. The display should read MAINTENANCE and all lights should flash in unison. Don't experiment in Maintenance Mode. Some functions will render your fax inoperable, except in certain foreign countries' phone systems. Every function is entered by touching just two digits. There is no Set or Start required, so as soon as you touch that second digit you're committed, with a few exceptions. One of those exceptions is the Purge function, which accepts modifying inputs. Touch 7, 6 to enter Purge mode. [Don't go looking for a comma key. I put that in just to separate the different key presses.] The display will read Cleaning All. If you had a problem with only one color, you would choose that color now by cycling though the list with the up or down arrow keys. In your case, stick with All. Touch the number 3 to select Power Purge, then touch the Black Start key. Sit back and hope.
When it's finished, the display will return to reading MAINTENANCE. Touch 0,9 to print that same test page you printed using the Ink button before. If it's good, you can exit Maintenance Mode by touching 9,9 or by unplugging the power. Either way, it will go through a complete startup routine before going to Ready state.
If the print has improved but isn't perfect yet, you can repeat the purge & test. If it still looks hopeless, it probably is. Brother has a one-year warranty, at least in the US. You can find a local service center on www.brother.com. If you are barely past the warranty period, call the customer service number and whine. They might issue a Work Order to the local servicer, effectively extending your warranty for this one problem. If you're using non-Brother inks, you're probably sunk.
If you have to pay for a new printhead and labor, forget it. Parts, ink, and time add up to more than a new machine.
Good luck.
Sep 15, 2010 | Brother MFC620CN Home/Office Color Inkjet...
Dell E176FP Monitor Stuck in diagnostic mode??
See if the set has some sort of reset button. If none do a hard reset on monitor to hopefully clear the cobwebs in monitor electronics and see what happens.
Mar 12, 2017 | Dell E176FP 17" LCD Monitor
Tv cuts on for a few seconds and right back off on its own
We had a Sony LCD burn out and display the exact same behavior. You have to isolate if your cable box/pc is even involved or if it's a power supply/backlit bulb issue or similar.
The way you test a Sony is to disconnect ALL cables except the power, power the monitor up and hit the Menu button to display the test pattern (it's a small box with some color bars with NO SIGNAL on the bottom since there are no cables connected). After a few seconds, this test pattern would also go black even though the green light on the LCD was on. So it was the LCD itself that was blown and nothing to do with the PC.
I'd see if your LCD has some sort of test pattern or test mode you can access in the menu's with no cables hooked up to see if it can hold that pattern for more than a few seconds before going blank. If not, it would be indicative of a burned-out or blown LCD rather than the box that is supplying the signal.
Aug 20, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Monitor revives only after cycling the power many times
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Aug 03, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
227 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
