Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Dishwasher my hotpoint dwf 33 does not empty when wash is over i have checked for blockages and cant find any does this mean the pump is broken
  • Anonymous Sep 17, 2008
    water does not drain, how do i access the pump?
    Genius:
  • 1,073 Answers
Check the drain selenoid
Posted on May 06, 2008
My dishwasher is not letting water out it has been ok in past its an hotpoint dwf 34
Possibly the pump is clogged or there is a blockage in the outlet pipe?
Mar 01, 2011 | Microwave Ovens
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
Hi I have a hotpoint washing machine model wt761 and it has stopped working, it will not drain. The display is showing an error code F-05. Can you help me please.
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 | Dishwashers
Blocked hotpoint dwf 33
There is a drain hose for your dishwasher and it often gets clogged. remove and clean it , reinstall and problem solved. If this doesnt fixya then might have to throw parts at it. Not sure though without cleaning the hose first. Good luck
Jul 13, 2009 | Hotpoint 24 in. DWF33 Built-in Dishwasher
Pumps in and out but does not wash
is the drain to far down the stan pipe or is the pip low down so just flows out hope this helps.
Feb 24, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 | Dishwashers
The dishwasher is not emptying out the water. It needs to reset and finsh the last cycle. Hotpoint DWF 33
pump under bottom front panel might be clogged remove hose clap from pump,cleanout,also can use shop vac.,also remove lower spray arm then remove filter clean and replace,also check under sink make sure drain hose is not kinked,thanks-mike
May 27, 2008 | Dishwashers
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
278 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
