Question about Systat SigmaStat 3.0 (sigmastat 3 up)
Sigma stat test malfunction
I can't run any descriptive stats, anovas, t tests, etc, without getting a no such test error message, and then some nonsense loop.
  • 6 Answers
SOURCE: TI 84 Silver Plus
I'm not sure, but it probably gives the error because one of the values you entered isn't valid. It's too big or too small.
For more information, look here:
http://tibasicdev.wikidot.com/2-propzint
If this doesn't solve the problem, please let me know.
Gr Marijn
Posted on Nov 29, 2007
22yooper
  • 828 Answers
SOURCE: admiral ref with freezer on top I need to find out how to get to defrost heater so I can test it
Defrosr heater is located behind the back wall of the freezer section. You will have to remove the shelves and ice maker if you have one installed. A number of screws secures the back wall in place. Remove the screws and the back wall should pivot out from the top.
The defrost thermostat is located behind this wall and is secured by a clip to the coil. To test this defrost switch you must lower its temperature below 16°F.
Posted on May 09, 2008
SOURCE: 2002 freelander coolant leak
My coolant leaked out and on top there is a large hard plastic container, I had to replace it, that stopped my coolant leak.
Posted on Oct 20, 2008
lesabre1972
  • 474 Answers
SOURCE: 2001 jimmy overheating
I would have your head gaskets checked for leaks into cooling system and if ok try changing your water pump.
Posted on Mar 29, 2009
SOURCE: norcold de251e t-stat lost part off the board
I found this. Hope it helps. http://www.landonedwards.com/carter/files/Thetford-Norcold/TekIISM.pdf
Posted on Jul 28, 2009
How do i calculate the standard deviation
for 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. you should be able to recognize what each variable means.
Oct 26, 2011 | Casio fx-300ES Calculator
Can you please help me on how to calculate mean, median, mode, standard deviation calculation on casio fx-991ms scientific calculator
This will show you how to do statistics (calculate average, standard deviation, regressions etc.) as to the mode and median refer to the definitions.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 19, 2011 | Casio FX-115ES Scientific Calculator
I don't know anything about physics or statistics or anything like that so I cannot do a test problem. :-( But I am in physics now and the professor said we needed a calculator that can do 1 and 2 variable...
Do not go buy another calculator because this one does 1-var, 2-var, as well as some regression models, and some distributions.
For 1-var and 2-var statistics read on.
Jan 22, 2011 | Casio FX-115ES Scientific Calculator
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
How do I get the variance, the standard deviation, and the sample standard deviation in a casio FX-115Es.. Thank you
The variance is the square of the standard variation
Oct 27, 2010 | Casio FX-115ES Scientific Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
How to do standard deviation
I assume you know the theory. I will only show you the key strokes for 1-Var statistics.
Press the number corresponding to the variable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
Hope it gets you started
Dec 06, 2009 | Casio FX-115ES Scientific Calculator
Standard deviation
Oct 16, 2009 | Casio FX-115ES Scientific Calculator
Standard Deviation
If you want to do statistics with this calculator you press [MODE][3:STAT]. You have then 8 options 1:1-var, 2:A+BX, etc.
For one variable statistics you press 1. Enter the values for the X variable in the template. Once finished you press [SHIFT][1](STAT) then select the value you want ( n, x bar , and the standard deviations (X sigma n) and (X sigma n-1).
Hope it helps.
Jul 30, 2009 | Casio fx-300ES Calculator
ANOVA
Nope, the TI-30XA is a one variable stat calculator.
Two variable stat is done OK by TI-36X or TI-30X IIS, also comparable HP or Casios
Sep 17, 2007 | Texas Instruments TI-30XA Calculator
Systat SigmaStat 3.0 (sigmastat 3 up) Logo
42 people viewed this question
Top Systat Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Systat Computer and Internet Expert? Answer questions, earn points and help others
