I would recommend using a PS3 repair guide to fix this issue.
To see all of the PS3 repair guides available on the Internet that have been reviewed, go to:
PS3 Repair Guides Reviewed
HI...
It needs major repair.
Check the web for someone with the right tools to fix it.
Sony wants $150..dont go there
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
SOURCE: when i turn ps3 on red light turns green then
Yes, what you have here is called the Yellow Light of Death, or (YLOD) for short. On PS3's, getting a YLOD is a 3% chance, while the XBOX360 gets a higher chance for the RROD.
I'm not sure exactly how to fix it myself, but hopefully this will help you.
http://www.youtube.com/watch?v=4_Ic1_TY-GU
SOURCE: My PS3 has a flashing red light, when I turn it
Hello there baileys 946 If you have the brief
flashing yellow light, then its followed by a red blinking light then
you have the yellow light of death AKA the YLOD. The lights are a
warning sign to let you know something is wrong. I can give you the
quick explanation, There are 2 chips on the motherboard inside the
PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the
solder heats up and when you finish playing it cools down, over time
this will cause the soldering to crack and the chips to lose
connection with the motherboard and you get the YLOD. WHERE TO GO FROM
HERE Option
1 - Call Sony In warranty the Price
is Free, out of warranty the Price is $150,
the whole process is 4-6 weeks You can call Sony and
they will collect the PS3, repair/replace, and deliver the PS3 back
to you Option
2 - Fix it your Self You can use a PS3 fix
manual to get this fixed easily and at home using household tools you
probably already own. Click
here to know more on PS3 Fix Manuals which has helped so many
people like you. Good luck Best regards Peter
